Question about Refrigerators
Kenmore refrigerator leaks water
I have a Kenmore 253.71822104 freezer over fridge refrigerator. Water is leaking on floor in front and can also sometimes be found under the two crisper bins at the bottom. Nothing else feels wet! I will check for gasket looseness per Bob Villa's site, although I'm not sure how to replace this nor do I know how to check for any other things which could be causing the problem (clogged defrost drain system).
Some other info: I have two cats and I suppose it's possible their fur may have clogged up the vent at the front bottom?...sort of doubt it, but it's possible. Also, I recall having a sticky gasket at one time (ie, the door would make sticky noises when opened/closed)....perhaps it is the gasket? Would that cause water to be found under the crisper bins? Yet, I see no droplets on the gasket itself......
I don't have the ice maker hose attached to a water supply as that had gotten crimped well over a year ago (so the ice lever has been pulled up to avoid any issues there) and had since then made sure the back of the refrigerator wasn't too close to the wall. Please help me fix this leaking issue. It started 2-3 months ago. Thanks!!
  • Randibou Jun 25, 2009
    By this you mean, unplug the refrigerator, go inside of the freezer and remove the panel or do I do this from the back side? Sorry, I can do this, I just need really detailed instructions. Thanks!!
  • Randibou Jun 26, 2009
    Okay, wish me luck. I'll let you know how it goes. Thanks for your assistance!!
    President:
  • 744 Answers
You have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Posted on Jun 25, 2009
  • Mike Price
    Mike Price Jun 25, 2009
    Go inside the freezer..take shelfs out...remove screws..take panel out..may be a ground wire attached..remove that from the panel.
    let me know if you need any more clarification :)
  • 351 Answers
Most likely you have a clogged drain. remove the back panel in freezer and you should see some ice and things clogging the drain take a hair dryer or unplug for 6 hours or better and you should be ok
  • Mark Nichols Jun 25, 2009
    you can get it from inside take the freezer panel off and also if you have like a long flexible small tube or hose that can easily flex you can force it from the back and clear the drain that way to
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Puddle of water on floor in front of side-by-side fridge. Fridge and freezer are cold. Drain pan is dry.
Lets make sure it is not something simple like a leaking water line behind the front kick plate. With that answered click here=> Leaking Refrigerators Just What may Be Happening Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks Sea Breeze
Sep 23, 2011 | Whirlpool Refrigerators
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water leaking into bottom of freezer and on rto floor in front. Kenmore elite bootom freezer 596 series
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Sep 14, 2008 | Kenmore Refrigerators
Refrigerators Logo
1,068 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
