Question about Dell Dimension E521 PC Desktop
E521 does not always completely start up into windows. It takes several tries of hitting the on switch. Is it the power supply?
  • 721 Answers
Dunno,if it hits the splash screen & quits or goes to black,then more than likely the hard drive is going bad. Doubt it's the power supply.
Posted on Jun 25, 2009
  • 20 Answers
It could be an issue with your Windows install and or an external device plugged into the PC.
Unplug all of unneeded devices like printers and such. If this doesn't help try booting into safe mode. If this helps you may have an issue with either a driver, service or auto loading application.
running msconfig in safe mode and disable all not MS applications is a good place to start.
Try these options and post an update
Posted on Jul 09, 2009
Both rear power windows go up slowly,4-5 switch hits before they completely up
Sounds like your rear power window motors are worn and tired, try spraying silicone spray in the window channels, if that don't help replace both motors.
Dec 22, 2015 | Cars & Trucks
My Dell E521 Desk Top Computer won't come out of stand by mode, what should I do?
Hi ,
When yo first start your computer , hit esc botton or f10 depending on what will take you to the start up mode and not the cmos settings , click on normal start up , if this does not work , take a bootable cd-rom and repair the system , dont reload windows ,..........Good Luck Roy
Nov 05, 2012 | Dell Computers & Internet
Dell e521 is stuck in power save mode and flashing the numbers 3 and 4
Try Hitting the Power Button. Some systems require you to hit the power button to bring it out of Power Save, Sleep or Hibernation.
May 15, 2012 | Dell Dimension E521 PC Desktop
My desktop dell dimension E521 won't come on. The power button just blinks green. A new power supply was tried but that did not work. What is it likely to be and is it gonna be worth fixing?
E521 motherboards are pretty reasonable: http://shop.ebay.com/i.html?_from=R40&_trksid=m570.l1313&_nkw=dell+e521+motherboard&_sacat=See-All-Categories so it is worthwhile to fix.
The 570 is a decent system although I am still an Intel guy myself
Aug 12, 2011 | Dell Dimension E521 PC Desktop
My dell dimmension e521 won't load to window screen.....i can't even get in to safe mode.......help
How did you try to get to safe mode. Have to tap F8 continuously for a while as soon as pc starts to boot. Holding key down might not work so it's better if you can keep tapping key quickly. If you have tried several times and can't get it to start in safe mode windows will normally put up an error screen to say windows didn't start properly with a few options. If you see this screen select last known good configuration and it might start to load windows normally if you are lucky.
Jan 01, 2011 | Dell Dimension E521 PC Desktop
Will not switch on. The light does not come on when plugged in at the mains
check the power supply, most have a little light on. might sound daft but if its a uk plug or has a fuse fitted in the plug that may have gone. try a different power supply, maybe take to a computer store and just ask them if they will try it on one of their power supply's as a test, of it works you can get multi fit power supplies quite cheap from well known auction sites. if it turns out it is not the power supply, it could be a fault on your main board, a fault with the power in socket (i have a toshiba and the pin inside the socket always breaks off, ive changed it several times) or more commonly to the older generation laptops, it ould be the battery. sometimes the battery completes the charging circuit, again knock off batteries maybe found cheap from well known auction sites, and alothough not always of great standards, they are better than paying toshiba for one and finding its a board problem.
Nov 20, 2009 | Toshiba Computers & Internet
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Dell dimension issue: system is gone off all of sudden.. it looks like there is a problem with the add on card which consists 2 USB ports and microphone and headset speaker.... but this card is connected...
It seems likely that you have somehow dislodged/interupted the graphics card GUI, which enables windows to come on the screen. Without this, the system will not boot properly due to the fact that your CPU is looking for it and cannot find it. You may want to double check to see if that card is in properly. Also, did you download driver for the new card? If not the right driver, it won't work. Another thing to check could be the IRQ I/O addresses (go to device manager/advanced) If they are not assigned a number, they won't work either. You can always hit F1 (it may be different on your comp, try f8 or f12) after you hit power switch, to see if it will give you the boot info before your OS starts up. Of course, you will not be able to see it if you have no video. Try to listen to the comp when turning it on. How many beeps does it make? It should only make 1, if it is making more, or a long one, you can find out problem that way.
Jan 30, 2009 | Dell Dimension E521 PC Desktop
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Dell Dimension E521 PC Desktop Logo
150 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
