Question about IBM ThinkPad R51 1830 (1830AHU) PC Notebook
Alarm/siren sound During the night, when the computer is not in use, I keep hearing a "siren" sound/alarm. Not sure why or how to stop it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Check any alarms that may be set. Lok at the system clock, and any timing applications. Check your anitvirus for schedualed times for scaning.
Good luck
Posted on Jun 25, 2009
Why would the alarm stop making sound.
Is their an on board fuse on the control panel. Also what you could do to troubleshoot is disconnect the siren red wire ad touch it to a 12vdc terminal on the panel. Make sure you are not touching it to a 120ac terminal. Are you talking the keypad makes no noice or the siren does not work?
Ed
Oct 05, 2014 | Honeywell Ademco Apx32en Alarm System...
I need to switch off my car alarm
Hi
You car is now of an age where by the ni.cads in the alarm have failed an are causing a current drawn when the car is turned off..the alarm sees this current draw as a theft so the alarm sounds.
Either replace alarm siren assy (fitted with new ni.cads) or remove the siren (or just unplug it).
Jul 06, 2014 | 1998 Rover 600
Beret 2 way 5000m alarm siren problem.
These Alarms are so very fickle. If the Alarm lasted a year, then you are out of warranty and I have removed more than my fair share of Alarm's. As the Vehicle owner, you need to realize that your problem is quite common and you should be grateful it has not complete immobilized your bike. My Recommendation is... Remove it and return it to Stock or spend the money and get a higher quality alarm with a great reputation. Don't truck the Install Shop, they get tied to one brand, find the Alarm that meets YOUR NEEDS...
Mar 03, 2014 | Motorcycles
The systems is working fine and no indications or warnings on the panels, but you can hear the siren at a low sound at all times. All the zones are working according to the panel and alarm monitoring...
The siren should not receive any power when in idle mode (non alarmed state). If you hear any noise, it receives some kind of low voltage. Is it powered straight from the panel or with external power supply and aux. relay? In any way - use a volt meter and measure across the sirens power terminals. If you have any voltage present check the source.
Nov 18, 2013 | Honeywell Ademco Wave 2 Wave2 Sirens For...
My alarm is testing multiple times a day
Check that the battery is installed the right way around. Most smoke alarms can only be tested manually (by pushing the button). If you are hearing a single beep every 50 or 60 seconds then this is the low battery indicator and this will sound if the battery is inserted the wrong way around. If the siren is actually sounding continually then your smoke alarm might be clogged with dust or other foreign matter. All smoke alarms should be replaced every 5 to 7 years as the components in them only have a limited life span.
Nov 10, 2013 | First Alert SCO7CN Battery Operated...
I don't have my key fob and when I opened the car this morning with the Valet key (?)(the alarm was set when I locked the doors last night) Alarm won't stop going off. How do I stop the alarm and drive...
Remove the alarm, its aftermarket this is better the alarm be removed, heres how remove siren alarm, then go underdash youll see a relay connected to the starter signal, jump the relay permanetly and your done for the flashing light cut the sensitivity ground of the alarm
Apr 16, 2011 | 1996 Dodge Caravan
The alarm doesn't sound when the alarm is tripped
This can be caused by either a blown siren power fuse on the motherboard or a blown voice coil in your siren. It would be best to have someone with an electronic background check this with a volt/ohm meter. If voltage is present at the siren during an alarm but there isn't any sound then you will need to replace the siren. On the other hand if no voltage is measured then you need to find and replace the fuse that sends voltage out from the motherboard to the siren.
Jun 20, 2010 | GE Security Simon 3 Wireless Home Security...
Siren goes off sporatically. We had to unhook the car battery to make it stop last night. The fuse is ok.
to stop at night you must cut the earth cable from siren, after that take the car at service to cek the wire and the contacts of alarm.
Feb 15, 2010 | 2003 Volvo S60
2002 Saab 9.5 Griffin 3L Turbo. Alarm comes on, for no reason?
Your alarm siren is the problem. You can replace the siren or have the Saab dealer program your car NOT to use it and remove it. When you turn off the ignition your SID will not display anything, unless the key in the ON or START position.
Dec 09, 2008 | 2003 Saab 9-3
Volvo s80 alarm
Have the codes read out for the vehicle. It is likely that the siren for the alarm is causing the false alarm. If the siren is bad, there will be a code set in the central electrical module. (CEM)
Jun 26, 2008 | 2003 Volvo S80
IBM ThinkPad R51 1830 (1830AHU) PC Notebook Logo
513 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
