Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
My Samsung LCD TV has developed 2 Green vertical lines that go from the top to the bottom of the screen and seem to be getting slowly wider as time goes on. The lines appeared after the 12 months warranty elapsed and the TV is now 2 years old. Is there any way I can get rid of these lines as on certain pictures, the lines are very obvious, especially on white backgrounds?
  • baj100 Jun 25, 2009
    Ricky, the lines are still there when playing a DVD.
  • 88 Answers
It definitely need service, this is a common problem with Samsung LCD TVs...
Posted on Jun 25, 2009
    Novelist:
  • 145 Answers
Some thing is wrong whit your antenna/cable wires if you don't see any of those symptoms when you
play a DVD movie that will confirm that is not your TV .
first tray checking all cables for loose fittings.
If you are on cable or satellite call customer service and get then to rewire your TV
Those symptoms you describe happen when you have a bad Coaxial cable more common
whit hose people buy pre-made cables at stores.
Radio frequencies from the air get in to the cable and get mixed whit you cable broadcast signal.
My Samsung PS50A410 plasma TV has developed two vertical lines down the right side, one at 60 mm and the other at 350mm. Both are approx. 20mm wide with an indistinct picture behind.
vertical lines as apposed to horizontal indicate bad lowerr connections in the ribbon cables inside the TV at the bottom sometimes they can be fixed but most times your panel is failed
Feb 12, 2018 | Samsung Televison & Video
I have a vertical line on my Samsung (PN50A510P3F) plasma TV. Would replacing the E and F buffers fix the issue?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 11, 2017 | Samsung Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Samsung lcd tv series 3 330
Aug 29, 2017 | Samsung Televison & Video
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
