Question about Polaroid FLM-3232 Television
3232 polaroid tv,makes popping noise when i turn it on.
My problem is that ive had my tv for 4 years and all of a sudden when i turn it on it makes a popping noise.ill turn it off and it wont make the n oise but when i turn it back on, loud popping!!after a while of it being on it will slowly go away but that takes ten min.what do i do??
  • 30 Answers
This sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Posted on Jul 22, 2009
My polaroid flm 3232 is 4 years old when I turn it on I get loud screeching and and popping sounds plus the picture is a color pattern. Can you help me?
Same thing happened. I unplugged it and everything for a couple of days then turned it on. Went to the menu and put reset to default. The V chip was then activated. If that happens to you too try 8202.
Dec 27, 2010 | Polaroid FLM-3232 Television
Our Polaroid FLM 3232 has worked for four years and now all of the sudden it won't turn on....seems to be no power supply...the red standby light is not illuminated....please help we love this tv!
I hate to say it, but it is prob the main board that went bad. (the board where all the inputs get plugged into) It is possible that it might be the power supply. One thing to check is to make sure you have 25v coming from the powersupply board to the connectors that plug into the main board. If you do have 24-25v than you will have to replace the main board. If not than the powersupply.
Dec 26, 2010 | Polaroid FLM-3232 Television
My Polaroid FLM-3232 TV Menu Window keeps popping up after the t.v. is on for awhile and wont go away. I keep closing the window but it continues to pop up. I had the Polaroid for about 4 years now. I had...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 10, 2017 | Polaroid FLM-3232 Television
Polaroid Model 3200 started with no sound then
This happened to my tv as well. I have a 62 inch polaroid. Were you able to fix your tv. If so what did you do and how much did it cost?
Sep 05, 2009 | Polaroid FLM-3232 Television
FLM 3232 by Polaroid won't turn on
Usually TV's have that period of time where they'll turn off after an hour or two of no one pressing  a button. If the problem persists, You could get another one and return the old one with the new one's receipt.
Aug 11, 2008 | Polaroid FLM-3232 Television
Sound suddenly went out on Polaroid FLM 3232...
I also had this problem with the sound suddenly going out. After spending hours determining that it was not caused by my cable box, and unlocking volume codes and such, I took someone else's advice and hooked up a cheap surround sound speaker system through the audio ports on the back. Now I have sound for my tv, and it even sounds better than when the tv sound was working.
Mar 01, 2008 | Polaroid FLM-3232 Television
Polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Jan 15, 2008 | Polaroid FLM-3232 Television
Polaroid 3232
i have found others that they did this same symptom when the ir board went out its only 9.95 plus installation.
Dec 11, 2007 | Polaroid FLM-3232 Television
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Polaroid FLM 3232 is making a loud crackling noise overpowering volume
Your only solution is to change the sound to mono. Eventually the power supply will go and the tv won't work.
Polaroid FLM-3232 Television Logo
528 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
