Question about Boating
Having trouble raising/tilting a 9.9hp Merc Outboard - Help!
I am trying to raise the motor out of the water and the tilt button on my NEW 2009 9.9 Hp Mercury Outboard is stuck. There are two postions.... Lock Tilt and Unlock. When I move the button to the Unlock position the motor still won't tilt. The motor is brand new... what am I doing wrong? Thanks
  • pnesbitt711 Jun 25, 2009
    Thank you for your reply. Are you sure that for a 9.9hp (Mercury Outboard) there would be a hydraulic system at all? The motor never ran in the water....we backed it in on the trailer in the down position and before putting it in the water wanted to make sure the motor would tilt upwards so that when we came up to the beach the propeller would not hit bottom. Can you tell me where I go to drain the hydraulic system you are referring to?
    Thanks again.
    Sergeant:
    Champion:
  • 226 Answers
Sometimes there is a lock lever just under the motor housing.youmay need to flip or pull and hold this lever while raising the motor by hand.hope this helps
Posted on Jun 25, 2009
  • 2,071 Answers
When having a trouble in raising / tilting either up or down once it reaches it's limit there is a hydraulic pressure relief valve that opens and lets the fluid bypass. I would be willing to bet that it ran so long with so much pressure it is stuck open. One thing you might want to try is to release all pressure in the system with the manual relief valve. Use a slotted large screwdriver and turn it out about two turns. Operate the trim up and down a few times (it won't move but will pump fluid). This is the manual relief valve and will allow the engine to go down, you may have to push a bit. Close the valve and see if the unit works now. If not the unit will have to come apart.
Remove the entire unit from the boat to work on it. Have a large metal pan to catch the fluid and hold a rag over any port you open. Please wear safety glasses. The units can hold a lot of pressure. Only work on one valve or port at a time and keep track of each check valve. Some of them under the motor are very small and easily lost. most parts are not individually available.
Good luck...
Regards:
VOTIT
Cannot raise or lower 115johnson outboard with manual relief valve open
If, even with relief valve open you can't raise or lower the motor by hand, your tilt tube is stuck.
remove your steering cable.
Remove the 2 big nuts on the tilt tube;
unbolt the engine from the boat
unbolt the trim/tilt system from sb and pt bracket.
Remove brackets. Remove tilt tube from steering bracket
Clean everything
Replace the bushings
Use triple-guard grease everywhere on reassembly
Jul 31, 2017 | Boating
While running my 90hp Merc 4 stroke engine dies,,, and no power to raise power tilt.... I wait a few minutes, then power tilt works & engine then starts Engine has no power, whe. Tilt has no power
I would be checking the tank vent is clear, then work along the fuel lines for air leaks preventing the pump from working properly
the power tilt should be electric motor operation and that indicates along with power loss, a low battery ( not charging) and if efi engine then that low power situation will result in low power for the engine controls
take it in for a proper diagnosis and quote
Sep 16, 2016 | Boating
What should the tilt be set at for a 12 ft pontoon with a 15 hp motor
Bill,
The tilt is dependent on weight in the boat, location of people, etc. The majority of people set it by feel. For a pontoon with low horsepower a general setting is set it so the propeller is horizontal to the floats (pontoons). Since you only have a 15hp on it I would set it this way. That way your propeller is pushing water straight back and all power is utilized in moving the boat and not wasted on raising or lowering the bow/front of the boat under power which is what your tilt up or down does. Raise it up your bow goes up. Tilt it down and your bow goes down.
Fred-
Aug 06, 2016 | Boating
The tilt trim motor will not raise or lower the outboard motor.
Use a multimeter to check that power is actually getting to the motor when you operate it. As you have suggested, the relays may be the problem, as they have bad contacts so no power is getting to the motor, in which case you need to replace the relays.
Jun 16, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
I cannot start the motor or raise the tilt and trim. Have power to the starter solenoid. have powere to the starter
check the control box , use multi metre and check the trim button and ignition key ! check main harness socket on the engine for corrosion or breaks in the wires !
Apr 11, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
How to raise manual tilt johnson (no tilt trim)
on the right side of the motor there is a lever that says tilt on it pull it up unlocks motor grab the top of motor and pull with all your mite
Mar 25, 2013 | Boating
How can i pump out power tilt fluid outboard completely remove. there is sea water mixed with oil in the system
un plug the line going to the bottom of the hydrolic cylinder put it in a bottle and try to raise your motor it should push the old fluid out into the bottle
Jun 30, 2010 | Yamaha 12V Air Pump
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Aug 31, 2009 | Boating
I have a 1994 150 hp Yamaha outboard motor with tilt-trim. My motor is stuck in the up tilt position and will not tilt down. It is working when I go up, but not down. I have talked to a used parts dealer...
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Jul 14, 2009 | Boating
Boating Logo
1,548 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
