Question about Sony Ericsson W550i Cellular Phone
Camera button i owned this phone since 2005. and now the main problem is, it wont take pictures anymore coz the button on the side of the phone does not function anymore even i pressed it hard.
  • 94 Answers
Oh sir ur problum is not a big problum. for me becouse i m a profeshional in this field. if u r a profeshional then u can solve easly buut if u r not a profeshional then u have to go nearest servicr center
Posted on Feb 22, 2008
A200 faulty selector switch
Same thing happened mine. Take out battery and leave camera for a few weeks until internal cell goes flat. Switch to "stills" mode and put battery back in. You will need to reset the date and time. LEAVE SWITCH IN "STILLS" mode for ever more.
Dec 31, 2011 | Konica Minolta DiMAGE A200 Digital Camera
How do I take pictures with my cell
One of two ways.
1) on the bottom right side of the phone there might be a button you can press that will lead to the camera app
2) in the main menu there should be a camera app you can go to
May 14, 2011 | Samsung Cell Phones
My camera wont take a picture anymore. I push the shutter button down and nothing happens
I have the same problem - it wont take pictures in auto focus mode but will in manual focus?? Help!!
Jan 05, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Volume buttons won't work, camera button wont work, and speakerphonew button wont work. Happened out of nowhere. Cannot lower/raise volume on side of phone, only vibrate works.
Welcome to Fixya's Community.
These problems HAve been related to a damaged flex cable.
This is the cable which in the U700 connect the lower part of the phone to the lcd part (with the screen, speaker, camera and touchscreen buttons). All the data such as screen images, camera pictures, speaker sounds pass through this cable from the main board which is located in the lower part of the phone.
Unfortunately, each time one opens the phone, the cable slides between the two part of the phone. In the long term, as the cable is thin and soft and this movement causes frictions between the cable and the parts, the cable consumes itself. the damage of the cable could results in weird effects on the phone.
In order to fix that you need to replace that part.
its easy.
just take the phone apart and locate the flex cable and replace it.
believe me you can do it yourself.
  • The Flex cable of your phone cost 3 $
  • A phone repair shop will fix that for 25 $
see if you can find it on eBay.
remember its SCH-U700 Not SGH-U700 there is a big difference.
Additional Help:
Learn more about Flex Cables.
Good Luck
Nov 10, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
How do i take pics?
Well, the easiest way is to use the botom button on the right side (edge) of your phone.
The other way is to press the Main Menu button on the main screen. This is the middle icon at the bottom of the screen that has 4 dots then go to Media Center.
Select Pictures & Video then Take Picture.
Point and press the camera button (bottom right edge)
To switch between Video and Pictures, press and hold down the camera button until either the camera icon or the video (movie camera) icon appears.
Once you take the picture, you have to select the second icon down on the right to save it to the phone.
Apr 09, 2009 | LG Dare VX9700 Cell Phone
Automatic camera
The camera buttons on the side are jammed down. This happens with the W850i and is a design fault. The reason you notice it randomly is because your hand will often brush off the camera buttons which are now so sensitive that the lightest touch will set them off. Same happened with mine but instead it switched the phone off when they were touched... When I realised, I popped the buttons out and stayed away from them as you can still take pictures using the touch screen :) I have the official repair document on the phone and it's easy to remove / replace the side pad but why bother. If it's contract then it's a well known problem and you should return but not accept the same model as a replacement as it will fail also. If return is not an option, then remove the side button and the phone is otherwise quite robust.
Nov 18, 2008 | Sony Ericsson W850i Cellular Phone
Canon Powershot Problem
Throw it at your driveway and see if that fixes it.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Camera wont work
take it back to where you bought it from and have a new one
May 17, 2008 | LG Shine KE970 Cellular Phone
Sony Ericsson W550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
