Model A6T12F2A. digital control panel is stuck on
Fedders model A6T12F2A. digital control panel is stuck on 75 degrees and low fan, but power and energy saver buttons work.
  • 1 more comment
  • jasonpuffinb Jun 25, 2009
    yes. some buttons work, some don't
  • Dan Webster
    Dan Webster May 11, 2010
    Have ya tried to kill power and let it internally reset?
  • Luis Mendez
    Luis Mendez Aug 18, 2014
    Display panel indicates "EE" what does that mean
  • 8,220 Answers
More than likely you is gonna have to replace the control.Sometimes getting a wash rag real hot and going over the buttons will help unstick them.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 25, 2009
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
Air conditioner model # A6T12F2A REV. A is cooling ok for a 2 to 3 min. at a time then it kicks down and blow warmer air out almost like it is reading like the room is cool and stops cooling maybe...
leave the unit off for about an hour to let cool off its hot and kickingout on the over loads . this is probley realted to a power problem or low voltage problem in you area due to demand
Jul 24, 2011 | Fedders Heating & Cooling
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Amana Refrigerator cooling problem
The energy saver switch doesn't really save you anything, all that does is turn off the mullion heater circuit which if you really add up the pennies on your electric bill, might save you enough in one year to cash in for a bite size snickers bar... leave that off. Replace the operating thermostat (freezer thermostat) to correct this problem. If you're concerned with being green, after you replace the thermostat, turn on the energy saver and see if this makes any difference, it shouldn't in operating temperatures. Wiring and diagrams are usually available at sears, or by visiting searspartsdirect.com.
Aug 06, 2009 | Refrigerators
I set ac at energy saver 71 degrees. The ac goes
yeah you have to be carfull the only thing that does is shut the inside fan off it does not mean anything. it is a selling thing
Aug 04, 2009 | Heating & Cooling
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Dec 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
My phaser 8560 won't say on, so it prints out the cleaner page and info pages daily after the very long warm up session. How can I keep it running so I don't burn through this very expensive ink.
Here you go.
To enable or disable the Power Saver (Energy Star) mode:
NOTE: The printer will only have the Power Saver menu selection if the printer was sold as an Energy Star machine.The Power Saver mode can only be enabled or disabled from the Control Panel.
  3. Press the [Up] or [Down] arrow button to select [Power Saver], and then press the [OK] button.
  4. Press the [OK] button until the required option is displayed; either 'On' or 'Off'.
  5. Press the [Down] arrow button to select [Exit], and then press the [OK] button to return to the main screen.
Oct 28, 2008 | Xerox Office Equipment & Supplies
Heating & Cooling Logo
417 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
