Question about Protech PTV-707 Television
A red "lock
A red "lock" image appeared on my monitor and remote is not even working...
  • 84 Answers
Just unplug the tv and reconnect your remote
Posted on Jun 25, 2009
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
No image, Just red and blue vertical line on display.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
How can I unlock it (Audiovox tv)?
you need to search your universal remote code for a audiovox code try all of the audiovox codes then once you find the right one, how you will tell is when you turn the tv off and on click menu then unlock the tv
Aug 08, 2009 | Audiovox Televison & Video
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
There is no image on our screen. The remote control does not work
it is locked.that is why there is a key there.it is a parental lock.
May 13, 2009 | Daewoo Televison & Video
17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
May 04, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Piece of s@#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
Oct 20, 2007 | Akai CTD-1390 TV
Nothing appears in the monitor
Try to check your hardware in your computer maybe it loose.try to insert properly the processor or other parts of your computer
Feb 15, 2007 | EliteGroup P4VMM2 Motherboard
Televison & Video Logo
184 people viewed this question
Top Protech Televison & Video Experts
Tom Chichester
damaso r claudio
damaso r claudio
Are you a Protech Televison and Video Expert? Answer questions, earn points and help others
