Question about Dishwashers
Kenmore quietguard standard wont start.
Kenmore quietguard standard has power, but will not begin the wash cycle. it worked just fine last week. The only thing I changed today--I turned on the high temp wash before starting. Door latch seems fine, too. Thanks in advance for any help.
  • 58 Answers
Is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Posted on Jun 25, 2009
I have a kenmore washer model#110.29832800 that will not start.if i put it in the spin cycle it turns on but will not start at the beginning of any cycle.it was working fine yeaterday.
then perhaps the timer contacts are burnt .sometimes they can be cleaned and last awhile but usually will need replacement of the timer soon
Jan 02, 2016 | Kenmore Washing Machines
We have a kenmore front loading washer that won't go in the spin cycle.
Try this site for answers. They have been very helpful for me. They also have parts I needed.
Apr 28, 2014 | Kenmore Washing Machines
Kenmore Elite Washer wont start
Plug off the wall socket. Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. This normally works.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 17, 2010 | Kenmore Elite 45986 Front Load Washer
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Jan 04, 2010 | Kenmore Dishwashers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 665.17012402 Normal Wash Blinking
Replacing push button panel also worked for me! Thanks for the solution.
Dec 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
1,121 people viewed this question
Top Dishwashers Experts
