Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
No Air is being blown in the fridge. fOOD STUFF IS GETTING SPOILY INCLUDING MILKcOOLING IS LIKE JUST A crisperoNLY VEGETABLES ARE FRESHURGENT HELP REQUIREDRGDSRAJESH S ANTHONYMUMBAI INDIAPh:+91-9969225566/9892292955annerajesh@yahoo.com
  • Anonymous Apr 27, 2008
    No air is blown inin the fridge
  • Labbu Apr 27, 2008
    no cool air is blown in my refrigerater
    Problem Solver:
  • 19 Answers
Check the door switch for open circuit,bridge out switch and check operation of fan motor,do not keep bridged for long period as it will cause the wireing to burn out.check the fan and also the normaly closed contacts on the defrost timer.
Posted on Nov 05, 2007
Why Select a Vacuum Food Sealer?
You may have heard a lot about food sealers but you may not know them very well. Food sealer can provide you with an easy way to seal your food by removing air from the packages so that they will not get bad when you want to eat it. We all have experienced that we put food in the refrigerators and plan to eat it later, but later never comes. It's really a huge waste not only of food, but also of money. The food sealers work to prevent that waste by keeping your food fresh.
With a food sealer, you can buy fresh food as well as vegetables and take them home. Food sealers make it possible for you to buy food in bulk since you can seal and freeze it to avoid waste. It will remain fresh after a long time compared with the unsealed one. By removing air from the packages, you can take all of the air out of the packages. If you have air in them or put them in the refrigerators, you will allow germs to get into your food, which will make it become unsafe. If you do not eat it within a "safe time" and it's not well protected from the air in your fridges, you will have various odors from other food inside your fridges that can mess up the flavor. Your food may become discolored. This is because the freezers' pulling moisture out of the meat and vegetables due to your container allowing air into your food. Your frozen food will dry in the end. Although it's still safe to eat, it won't taste as good as it originally is. Food sealers are systems that seal food in air-tight vacuum packed systems like pouches and used for foods that need to be stored for long periods of time.
Anyway, food sealers can help reduce oxygen, limiting bacterial growth that would otherwise cause vegetables, meats and liquids to spoil. Sealing food guards against dehydration and freezer burn, and also saves on storage space because of the reduced size of the packaging. As an added perk, you can use the vacuum sealer to marinate meat or combine foods for ready-made meals. http://www.vacuumsealermanufacturer.com/
Aug 14, 2017 | Select Kitchen Appliances - Others
My fridge is not freezing
Somewhere along the way, the air going from your freezer's evap coil to your fresh foods section is getting blocked.
Check to make sure the lower back of your freezer wall (inside the freezer) isn't frosted over. If it is, you need to repair the defrost circuit. Next, make sure you can hear the fan in the freezer running. Then, check the damper opening between the freezer and fresh food wall.
Oct 24, 2014 | Refrigerators
Fridge keeps freezing food
I have a 6 year old Kenmore Elite top freezer.. I have been dissapointed from day one with this fridge.. the fridge has air vents all over the inside of the fridge. We find that if one of these vents have anything in front of it that something somewhere else in the fridge will freeze. Its very frustrating.. I find that I loose allot of fridge space because I am always juggling space to make sure that these vents are always open... very bad design.. sounded like a good idea at the time.. but never again..
May 08, 2012 | KitchenAid Refrigerators
The freezer is working perfectly fine bt in the fridge compartment even at minimum temp the cooling is so high dat it leads to ice formation in d fridge. becoz of which all my vegetables n other food stuff...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 02, 2011 | Samsung Refrigerators
I have a Whirlpool GI5FSAXVY. The vegetables are freezing in the vegetable bin located under the ice maker. I set the tempture to 40 degrees and the problem continues. Can you help correct this? Thank you.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Also check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this will helpout in solving the problem..
Jun 14, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
My fruit and vegetable drawers keep freezing my fruits and vegetables. What could be causing this to occur?
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
Oct 31, 2010 | Refrigerators
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Fridge too cold
First, clean it the unit out and fully defrost.  Clean the condenser coils.  Don't pack in so much food, don't open the door too frequently.  Never block any air channels. Never leave uncapped liquids in the fridge or freezer.  Set the fridge at about 40 degrees...use an outdoor thermometer.  Freezer at about 0-5F.
Aug 21, 2008 | Kenmore 64802 Top Freezer Refrigerator
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
89 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
