Question about Maytag 24 in. MDB7650AWS Built-in Dishwasher
My Maytag Dishwasher DWU9962AAB randomly stops during any cycle. I got very frustrated and kicked it then it started working again. Since then if I lean up against the door when it stops working it will start working again.
Had same problem with same model. replaced door switch/latch. $30 part. common problem
Posted on Oct 17, 2009
  • 999 Answers
There is a loose or semi broken wire in the door harness or the door switch needs adjusted.
Eric
Posted on Jun 25, 2009
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Maytag dishwasher stopped mid cycle with water in bottom. no touch buttons work. Should I start looking for a new one?
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Sep 09, 2010 | Maytag MDB8601AWB Built-in Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Maytag 24 in. MDB7650AWS Built-in Dishwasher Logo
328 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
