Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
DI1610fp When I try to fax I get "no loop current" error message.I've moved this printer from a different location to where it is now. It was fine at the old location. The printer that was at this location also had no issues, and I've tested the line with a phone and had no problem
You tel line is not working plug a phone into the wall jack and see if you get a line
Posted on Jun 25, 2008
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Konica Minolta Error Code: C14A3 Blown fuse or Exposure Lamp Printer was printing black and suspect it may be the lamp. Where can I get a replacement and instructions on replacing it myself?
Go to a Konica Minolta dealer and ask for assy, the part number is 4980 1001 01 and it is called CCD MODULE. I cannot find only the lamp, you'll have to replace the full assy in which the lamp is included.
Jan 15, 2009 | Konica Minolta Minolta DI1610FP...
Error code F-35-6 on my konica 7022 copier
You could try to reset the code. F35-6 is a fuser code, either you have a power surge later or bad thermistor in the fuser unit. Power off your machine, while hold down 2 and 5 button power the machine, this should take you to the 25service mode. in the softswitch mode go to switch #3 turn bit 1,2 and 3 to 0. than power off and on your machine. if this doesn't work you need to replace your thermister and possibly the thermostat.
Sep 17, 2008 | Konica Minolta Minolta DI1610FP...
Error 441*
Error #441 is caused by poor line quality accross the telephone line or faxing to a non-compatible fax. Try faxing to someone else as a test, if it still happens, try moving the fax to a different phone jack. You can also try faxing at a differn't time. Also try replacing the phone cord attached to the fax.
In all cases it's either phone line, phone cord or non-compatible machines (old fax on receiving side).
Aug 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No loop current
I believe that with this model there are 2 places to insert a phone line and you may have them backwards, also, it could be a bad phone cord that your using... check these easy things first...
May 05, 2008 | Office Equipment & Supplies
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
138 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
