Question about Craftsman 24 Hp 48" Deck Yard Tractor
I am another owner of the 24 hp. briggs and stratten ELS that has blew a rod out the side. How can I get help replacing this motor that has been such a terrible problem
  • allenthielem Jun 26, 2009
    Thank you it is ashame that a company can put out an engine that they had to know was defective. I guess it was worth the risk to not fix the problem. In my opinion I do not want anything to do with there motors Thank you for your time.
  • 376 Answers
SOURCE: Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
Posted on May 28, 2009
rwvanlue
  • 486 Answers
SOURCE: i have a 24 hp briggs & stratton els 725 motor
The engine ignition can be interupted by a safety switch (seat) out of place or adjustment, or a carburetor fuel solenoid that is loosing it's supply of voltage.
1) Check the wiring at the starter area, looking for a main engine wiring harness plug-in.
Check for connections that are burnt or loose.
2) If you can locate the 'kill' wire connection at the main harness, disconnect it, and retry the engine.
3) If the engine continues to fail to run properly: you might replace the plugs first, then I have listed a few things to check. They may not all aply, but this may help with an idea or two to try.
1) Determine that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 23, 2009
  • 3600 Answers
SOURCE: I blew my connecting rod on my Briggs 20hp and replaced
You most likely have a bent or burned valve, if you put it at top dead center and apply some air to the cylinder see if you hear a leak from the intake or the exhaust pipe if you do that will tell you you have a bent valve. hope this helps and thanks for using Fix-ya.
Posted on May 05, 2010
  • 580 Answers
SOURCE: I have an OHV Briggs
You may have water in the gas or a blocked gas filter. Check this out. Make sure your carb float & bowl has no water or sediment buildup in them. Carefully remove them, clean & replace. Make sure the power jet is clean also. Good luck!
Posted on Feb 19, 2011
BAMOUT
  • 2478 Answers
SOURCE: can I replace connecting rod Part #692419 with rod part #494504-S. I have a 17 hp Briggs and Stratton Model #310707 Type 0137-E1
You need to go by serial no.
Posted on Sep 18, 2012
I have a briggs and stratten 23hp ohv rider where is the oil drain plug
usually comes off the bottom side of the motor thru a pipe with a cap on the end .
Jan 16, 2016 | Measuring Tools & Sensors
I have a craftsman gt5000 garden tractor 24hp els motor that threw a rod, the end cap broke loose.will the briggs and statton 27hp model 44Q777-3136-g5 work as new motor,the cranksaft dia. and length are...
There should be no reason why not, Just keep in mind of the bolt pattern and measurements as well as you may have to make a few altercations for cables but if shafts match you should be good to go! I hope this helps.
Sep 25, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
yes it is possible to put them in backwards, there are triangles on the rod and crank that have to be on the same side in order for it to be correct. If it is missfiring you also need to check you timing key on the crank. since you broke a connecting rod I would only have to assume that you sheered the timing key as well.
May 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
24 hp engine. one bent push rod, second rod missing
just found the same problem on my father in laws mower (24 hp briggs) I took the engine off of the mower, drained oil, turned on its side and removed lower case. There was the missing pushrod wraped around the camshaft gear. no clue on how in the hell it did that! It also ended up breaking the govenor (quick look) will look for more damage tomorrow.
Jun 23, 2009 | Briggs & Stratton Garden
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
