What should i do to fix this error? Canon i-sensys mf 9220 showing system error E000003 on screen
What is the Canon i-sensys mf 9220 system error E000003?
The Canon i-sensys mf 9220 system error E000003 is an error that can occur when you're trying to print documents. Basically, it means that the printer can't communicate with the computer. This can be caused by a number of things, but the most common cause is a problem with the USB cable.
How to fix the Canon i-sensys mf 9220 system error E000003?
If you're getting this error, the first thing you should do is check the USB cable. Make sure that it's properly connected to both the printer and the computer. If the cable is loose or damaged, try replacing it with a new one.
I hope this helps!
