Question about Dell Latitude D410 Notebook
D410 stopped recognizing battery and cursor became unstable
Upon boot-up this AM my heretofor trouble free d410 stopped recognizing battery and cursor became unstable after normal shut-down last evening. Under settings, system, power mgt the battery icons indicate "not present" which is erroneous. Pulled the battery and reinserted - - no joy. Using logitech trackball on usb port appears to stabilize cursor.
  • 61 Answers
As a one time Dell Field technician I've seen the battery problem many times before--
Your motherboard has likely gone bad. No real relation to the touch pad problem, but I would replace the motherboard before attempting to diagnose the touchpad.
Swapping the battery with a known good one would be a nice first step if you have a spare (or you know someone with the same model laptop), but it will likely confirm the motherboard as the problem.
Posted on Jun 25, 2009
I installed a new battery into my HP G60 233NR. However sometimes when i power on my computer i get a black screen. Sumtimes after sitting for awhile it will boot. Other times I have to unplug the battery,...
I have a G62 that I've taken apart a couple times to fix issues. Right now the video card has an issue with turning on. I can get it to work by turning the brightness down before I shut it down; it will boot normally usually. If not, I can flip the screen open and closed a few times and it will finally get going. It's a backlight powerup problem that I haven't the patience to sort out. The battery has nothing to do with it, except it diddles the voltage a bit and might get the display working. I can't see the bootup screen, though; if I want to change anything, I have to connect an external monitor.
I usually blow the dust out of it with an air compressor every few months (I use it rarely). Otherwise the heat sink and fan cruds up with dirt and overheats.
I like the PC even though it's 6 years old. It runs all distros of Linux nicely. Mint, openSuSE, Ubuntu, Bodhi, Puppy, Manjaro.
Apr 06, 2017 | HQRP Computers & Internet
Comaq presario cq 71 cursor is frozen. PC shop man siad it was poor battery. Booted up from mains and cursor worked fine until recently. Mistakenly left battery in and powered down to hibernate. Now cursor...
yeah ..you have to disable the power saving mode..This is the only thing related with the battery usage that may disable the cursor..o r..just reinstall the touch pad..
to do that download its driver and run it into computer ..
here is the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795238&
just select eh operation system and download the touch pad driver..
or go to control panel ..open the touch pad icon ..and in there select default settings ..or enable the cursor again ..if it is disabled..
if this is not working ..try reinstall it like I said ..It always starts a clean installation from the factory settings ..
Avoid hibernate it ..cause will always preserve the last settings ..just close it proper each time ..this way it will boot and recognize devices each time from the start ..
Dec 06, 2010 | Compaq Presario CQ50-215NR Notebook
Upon start up, there is a blank screen with a cursor that goes no further. wh at are possible problems?
Shut down the computer and restart after 5 minutes. If same problem happens again you may have a corrupted hard drive. Before Windows boot, try to enter the BIOS or setup. Check the BIOS to see if it recognizes the hard drive - it should be listed, if not then the harddrive is bad or not connected. Also, see if it can boot a bootable CD (like the Windows setup disk) - set this up it in the BIOS to boot a CD.
Oct 29, 2010 | Computers & Internet
Drive is not reconized
Hello impurrfect,
Since you have completely removed the drive from the computer, remove the CMOS battery(big watch battery) on the motherboard for about 30 seconds then reinstall the battery, then reboot. This time however, when you press the power button to bootup, you need to start tapping F2 about 2-3 times per second to access the BIOS. If the F2 key does not work, try using F1 or maybe even the Delete key.
BIOS screenshot: yours may look a little different but the concept is the same.
http://drivers.softpedia.com/get/BIOS/Iwill/Iwill-XP4evo-Bios-105a.shtml
Once in the BIOS go to BOOT or BOOT DEVICE, something to that effect and see if the drive is listed. You will also have to reset the system time while in BIOS so now is a good time to do that as well.
Regardless If it IS or ISNT listed, go ahead and exit the BIOS and choose YES SAVING CHANGES. Your PC will now continue to boot into normal mode. Once in Normal Mode, go ahead and go through Shut Down and once shut down, reinstall the drive and hopefully the PC will recognize it as a new device. Then you can visit the manufacturers website for firmware updates.
Jul 10, 2009 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Dell D410 Latitude won't boot up when connectd to docking station
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Apr 11, 2009 | Dell Latitude D410 Notebook
Battery Problems
If the battery is over a year old, then odds are you need to replace the battery.
Sep 02, 2008 | Dell Latitude D410 Notebook
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Dell Latitude D410 Notebook Logo
642 people viewed this question
Alun Cox
