Frigidaire Portable Air Conditioner
Problem for Frigidaire (FAP094P1Z) Portable Air Conditioner
We have a 9000 btu portable frigidare air
By kpuzynski on Jun 25, 2009
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally we have water dripping from the hose outside, leading me to believe that the pump works occasionally.
Best Solution
posted on Jul 08, 2009
Very Helpful)
Sparks001
Rank: Apprentice
Rating: 88%, 2 votes
How high up is your exhaust hose in relation to the unit - if it is too hight, the pump may be struggling to discharge the water.
I assume this is a vented model, where you have a large diameter pip exhausting air outside (Around 110mm wide) if so, is there also a smaller pipe to carry the condensate water?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 25, 2009
Very Helpful)
TheMobilian
Rank: Guru  Frigidaire Expert
Rating: 89%, 717 votes
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Portable Air
Questions and Unsolved Problems for Frigidaire Portable Air
Do you recommend Frigidaire (FAP094P1Z) Portable Air Conditioner?
Answer
Answer
Our Frigidaire FAP094P122 is leaking. At first I traced it to a pinch in the black drain hose. By... (More)
Answer
The water reservoir fills up and the pump no longer drains it.  The problem just began and... (More)
Answer
Hello there. I would like to seek views on this really cool product from Plasma Cool portable air... (More)
Answer
I just bought the Frigidaire Portable Air Conditioner and it is making a very loud sound. There is... (More)
Answer
the air conditioner freeze then the water leaks out on the floor it does not drain through the hose
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
