Question about Sony Playstation 3 (PS3) Console
Shut down my ps3 with the switch and now have to rebuild the hard
The game froze when i was in a game and i held down the reset button but it did nothing and i had to use the switch. then when i turned it back on it showed nothing. it took me a little while to figure out how to get to the reset menu and i i restored the file system and then i told it to rebuild the data base. ive had it going for a 1 1/2 and still it gets to only 1% or 2%
Can i get a little info on this problem
  • 6,784 Answers
Ok, you will need a new hard disk. it has become severely corrupt at this time. this is basic hard disk failuer.
contact Sony for this repair.
Posted on Jun 25, 2009
I bought call of duty world at war and then i got the latest map pack when i hit download the ps3 totally froze so i tried and tried again but it just didnt work so not having much on my ps3 anyway i...
Try updating your system the manual way:
recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Perform 6, "system update."
If this doesn't work, when your system froze and you powered it down, you may have corrupted your Hard Drive (Hard Disk). You will need to replace it.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
My ps3 heats up quickly after i turn it on, then it shuts off.
Try a hard reset.
Hard Reset procedure for the PS3 Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
My ps3 froze the other day . So i waited but it didnt unfreeze . so i tried to press the middle button on my controller and the menu did not pop up . so i tried to reset it &&the green light...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
• Restart System: Restarts the PLAYSTATION®3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 10, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my PS3, No image comes up on the HD Channel which i play the PS3 on, however the channel settings recognise a signal from the cable but still no picture
I would first try a simple reset. To do this turn the PS3 on my pressing the power button, except hold it down, keep it held until it beeps again and shuts down.
Once it shuts down from you holding the power button, turn it on normally and see if your video settings have returned.
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
The ps3 froze and it can't read blu ray disk anymore. I played mw2 with the latess update installed on your ps3 and at some point it froze. tried pressing the PS button but nothing happened. I had to hold...
You have the same problem i had just a couple of weeks ago you need to call sony and tell them your problem and send it in it will cost $140.Their phone number is 800-488-7669 .This happens when you play MW2 to much but its hard to stop its so fun.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Games wont load
try reseting
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • That's it, your video settings are reset and you should be able to choose your input and configure it from there
  • Also
    Hard Reset procedure for the PS3 (as instructed by Sony CS).
    alsoMe and some other people thought that the Reset button was on the back, on the upper center with the white marking. Thats not the reset button. The reset button is to the right. You need a machanical pencil (with lead extended) to poke it.
    Dec 31, 2009 | Sony Playstation 3 (PS3) Console
    Freezes on the 'Rebuilding...' screen.
    The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
    If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
    This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
    Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
    Playstation 3 picture reset
    hey kg did you shut the system off then wait for the red light to appear then hold it down until it beeps?
    if you did this several times and it did not work try changing the tv back by going into settings and switching it back over.
    Jun 30, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    43 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
