Question about RIM BlackBerry Curve 8310 Smartphone
BB Curve 8300 just started having a charging problem. When plugged into the USB cable, PC displays "Power Surge on Hub Port". I tried it on different hubs and different PCs. Same result. is my USB port on BB fired/shorted?
    Brigadier General:
  • 7,752 Answers
Your need to replaced the usb or the usb charging port on the phone.
Posted on Jan 30, 2010
The blackberry curve keeps showing app error 523 i have tried the above and whenevr i plug it in to the bb desktop maneger the bb desktop maneger turns grey HELP
try this... plug in ur celfone in pc. run blackberry deskstop sorftware. click organizer.check calendar/memo/address book/task. then click configure... if you see downloading in your celfone dont wait to finish downloading ... just quick plug it out your usb celfone...
Jan 25, 2011 | RIM Blackberry Curve 8300
When plugged into pc get error on pc power surge on usb hub port
Some computers have a limited power capacity on the USB ports, another possibility is that your gps battery is too low to be charged via the USB connection, try charging it with a wall or car adapter first, then connect to your pc.
Jan 10, 2010 | Garmin nuvi 250 GPS Receiver
Will not charge
Are you using the AC Adapter, or USB sync cable to computer to charge? If using your computer to charge, you will need to have USB Driver for your BlackBerry Model installed. Download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5It
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your Battery http://www.amazon.com/Blackberry-External-Battery-Charger-8300/dp/B002YGYLA8/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263514496&sr=8-2
Dec 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Need to email photos from blackberry to computer
1- Install the BlackBerry Desktop Manager Software on your PC
2- Use the USB cable to connect the BB to you PC
3- Navigate to the BB (just like a USB stick) and you have a folder with all the pics in it.
Hope this was helpful...
Nov 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
How do i transfer music from pc to bb curve 8300?
You can't put songs that you have bought from apple. You can put songs that you have riped from CD's or downloaded. You need a micro SD card. On the phone go into options: Advance Options, Media Card. Turn mass storage mode on. Now plug your BB into the computer and a little window will open up. open the Blackberry folder then music. Drop and drag your music files into that folder. if your going to use the Desktop software go to google and type: Blackberry Desktop Manager 4.5. This version comes with a media manager. http://crackberry.com/blackberry-desktop-manager-version-4-5-now-available Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | RIM Blackberry Curve 8300
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Power surge on hub port
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Jan 28, 2009 | Dell Dimension 4700C PC Desktop
I am having to send my wife's curve out for repair today as it seems that the very fine connections made to the circuit board from the power port have come away. This port seems to be very fragile, and poorly designed IMHO given that it has to be used so frequently.
Sep 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
May 15, 2007 | HP Deskjet 5440 InkJet Photo Printer
RIM BlackBerry Curve 8310 Smartphone Logo
150 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
