Question about HP PSC 2410 All-In-One InkJet Printer
The on light is flashing and hour glass is showing and printer makes clicking sounds. It does not grasp the paper to pull it in.
HP PSC 2410 PHOTOSMART ALL IN ONE PRINTER PROBLEMS
FOR EVERYONE OUT THERE WHO IS AT YOUR WITS ENDS WITH YOUR HP PRINTER THAT IS TOTALLY ABSOLUTELY STUCK IN STARTUP
AND MAKING THAT AWFUL CLICKING NOISE ---- LET ME TELL YA ---I TRIED EVERYTHING--I MEAN EVERYTHING
I WAS JUST ABOUT TO PULL ALL MY HAIR OUT--- I READ ALL THE POSTS AND DID EVERYTHING RECOMMENDED
FROM POSTS OF OTHER USERS AS WELL AS THE SORRY HP WEBSITE!
I DID NOT WANT TO TAKE APART AND CLEAN GLASS AND STRIPE B/C I WAS AFRAID TO DO THIS, BUT I THOUGHT I AM GOING
TO THROW IT AWAY TODAY ANYWAY AFTER WHAT I HAVE BEEN THRU SO I STARTED TEARING INTO IT AND -- EVENTHOUGH I AM NOW
IN TEARS B/C IT REALLY WORKED---LOL I DIDNT REALLY KNOW WHAT I WAS DOING SO LET ME TELL YOU HOW TO DO IT NOW THAT
I KNOW --LOL LIFT THE LID FOR YOUR SCANNER AND THERE WILL BE TWO SCEWS ON THE LEFT. I USED A TINY ALAN WRENCH
(WORKED GREAT) TAKE THEM OUT AND THEN OVER ON THE PANEL SIDE, TAKE A SCREWDRIVER AND LIFT FROM THE BACK-JUST POP IT OFF.
I DID NOT TAKE ANY OF THE RIBBONS LOOSE. 2 SCEWS WILL BE UNDER THE COVER, REMOVE THEM, ALSO REMOVE THE SCANNER LID BY PULLING
TAB TOWARDS YOU ARE LIFT THE LID STAIGHT UP. I JUST LET EVERYTHING HANG AGAISNT THE WALL WHILE I WAS WORKING. I TOOK THE GLASS
OUT AND USED MY SPECIAL LIL CLOTH THAT CAME WITH MY FLAT SCEEN TV AND CLEANED THE GLASS REALLY WELL, PAYING VERY CLOSE ATTENTION
TO THE BLACK/WHITE AND MIRRORED STRIP. (MAKE SURE THE BLACK/WHITE STRIP IS DOWN PUT IT ALL BACK TOGETHER ) I DIDNT EXPECT IT TO WORK
BUT IT DID!!!!!!!!!!!!!!!!!! I KNOW THIS IS LONG BUT GOSH I HOPE IT HELPS EVERYONE!! TAKE CARE ALL, KATHY
Posted on Jun 30, 2009
  • biglou72 Dec 01, 2010
    Thanks this helped! Only issue was with the panel. I broke the back tabs and then realized I had to slide a butter knife in the front of the panel to press in a holder and then the panel slides out forward and comes out very easily.
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
My hp 2360 wont print, green light keeps on blinking, it says printer offline on the printer status bar
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means
The Power light can flash for several reasons:
? The printer cover is open.
? The printer is out of paper.
? A problem exists with the printer, such as a paper jam or a problem with a print
cartridge.
For information
Jan 30, 2011 | HP Deskjet 2360 InkJet Printer
I have a DeskJet 5940 which was about to be thrown away and I thought I'd have a go fixing it. I tried, but it simply won't work. When I print something it pulls one paper nicely from the tray, feeds it...
  • Reset the product
    1. If the Power light is on, press the Power button (c01346625.gif ) to turn the product off, and then continue with the steps. If the Power light is off, go straight to step b.
    2. Unplug the power cord from the wall outlet.
    3. Plug the power cord back into the wall outlet.
    4. Press the Power button (c01346625.gif ) to turn the product on.
    5. If any lights are still blinking, service the product.
  • If the print-cartridge status light stops blinking after you reset the product, follow these steps to make sure the driver settings are correct, and then try printing again.
    1. Open the printer driver.
      • Windows 2000 : Click Start , point to Settings , and then click Printers .
      • Windows XP : Click Start , click Control Panel , and then click Printers and Faxes .
      • Windows Vista : In the Windows taskbar, click the Windows icon (c01364735.gif ), click Control Panel , click Hardware & Sounds , and then click Printers .
    2. Right-click the icon for the product, and then click Printing Preferences .
    3. Click the Paper/Quality tab.
    4. In the Paper size: drop-down menu, click the appropriate paper size.
    5. In the Paper type: drop-down menu, click the appropriate paper type.
    6. Click OK to close the dialog box.
    7. On the product, press the Resume button (c01421637.gif ) to continue printing.
    Also Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
  • Dec 17, 2010 | HP Deskjet 5940 Photo InkJet Printer
    Red light stays on and printer won't print
    My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
    Jan 16, 2010 | Epson Stylus C60 InkJet Printer
    Scanner bar seems jammed, printer shows busy, all docs cancelled
    Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
    Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    On light won't stop blinking and on the display there is an hour glass
    there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
    Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
    HP C3150 Printer Continuing Paper Jam Errors
    Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
    Jul 04, 2008 | HP Photosmart C3150 Printer
    Black streaks are appearing on printed page when scanning
    Do the lines only show up if you use the document feeder? If so, there is something on the strip of glass where the page is scanned. Open the top to reveal the large glass area. Then open the part where the paper feeds in when using the document feeder. It will flip open from right to left. There are two pieces to this, so make sure you grasp it as low as possible. You should see a small strip of glass. Clean all the glass with a SOFT cloth. Don't spray any cleaner onto the glass, rather, spray it onto the cloth if you need any.
    Apr 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    HP PSC 2410 All-In-One InkJet Printer Logo
    763 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
