Question about Weather King 10AJA2501AH Air Conditioner
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
  • Weather King Master
  • 8,220 Answers
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 25, 2009
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Dont no how to work central heating system
Honeywell Focus Pro 5000 non programmable is the easiest heating cooling thermostat that I've seen.
Dec 23, 2011 | Heating & Cooling
Honeywell RTH2310b thermostate - my thermostat worked just fine through the winter with the heat but now it won't kick on the central air. I have tried switching the yellow(cool) and the white(heat) to...
You can check your float switch, power to both the air handler and outside condensing unit and ensure power is present, also check control voltage from transformer ensure 24Volts on secondary side. If you are not comfortable around electricity though I recommend you call your A/C Contractor for safety reasons.
Further information would be needed to further diagnose your problem.
Jul 05, 2011 | Honeywell Heating & Cooling
I installed a new Honeywell RTH7600 thermostat from old Honeywell thermostat. It shows heat is on but no air is coming out of vents. I dont even hear system working. I have a heat pump system. I set the...
Are you completely sure you have the Reversing Valve wire in the right place? Some reversing valves are powered for heat, some for cool. Make sure you know which yours is, or perhaps change that setting (see the manual) on the thermostat to try it.
ALSO, sounds like the FAN wire may not be in the right place either. Did you carefully note the wire colors on the old stat before you started, or perhaps take a photo?
Feb 28, 2018 | Honeywell Programmable Thermostat Heater
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Installing thermastat
any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Oct 30, 2008 | Honeywell Heating & Cooling
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
I'm trying to turn on the central air conditioning in my new apt, and it's not working. I'm flipping the switch on the bottom right to Cool. It's blinking "Cool On" but also says...
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Sep 01, 2008 | Honeywell Heating & Cooling
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Weather King 10AJA2501AH Air Conditioner Logo
110 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
