Question about GE 13TVR60 Combo
Why does my technike tv keep making loud cracking noises?
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
My tv is making a loud roaring noise in the back
I had the same problem, it was the color wheel (part # 270916). The bearings go and it starts making noise. It was fairly easy to replace.
Jan 16, 2009 | RCA HD50LPW175 50" HDTV
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Hitachi 65 in rear projection tv
can you identify the flashing item because it sounds like the flyback or the high voltage splitter can you send me a picture of the part thats flashing white please?
May 09, 2008 | Hitachi 65F59 65" HDTV
Rear screen tv
flayback transformer or tv tube.
i would think it's worth reapir.
Nov 26, 2007 | Toshiba 42H83 42" Rear Projection...
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
GE 13TVR60 Combo Logo
44 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
