Question about Waring RB75 Specialty Blender Stainless Steel 3 Speed Blender
How to replace coupling on Waring HPB300
How do I replace the coupling on a Waring HPB300 blender?
Thanks.
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
  • 16 Answers
SOURCE: 40 yr. old Waring blender
plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
SOURCE: Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Posted on Nov 15, 2008
  • 11 Answers
SOURCE: My Waring blender fuse burnt out. Where do I find a replacement?
It's not a typical fuse, it's a thermal protective fuse. Looks more like a diode. They sell them a Radio Shack. You'll have to use crimp connectors to replace because a soldering iron will ruin it.
Posted on Apr 29, 2009
SOURCE: Waring P320CX blender parts required
Hi - there is a website called nisbets.co.uk that has all the spare parts for this Waring blender, plus a great diagram which is much better than anything in the blender instructions.
Posted on Jun 07, 2009
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China.
If so, the chances are really slim for a finding parts for a fix.
If it was made in the USA, try "e-bay" for parts.
If you need a parts list, you will need to find one first.
Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site.
God bless your efforts.
Sep 16, 2016 | Waring Blenders
The coupling spins on my Waring Pro SDM50 2-Speed Blender, but it can be stopped by hand and does not spin under load. What is wrong and how do I fix it?
The most likely cause here is the motor brushes are going bad. That is dependent on how old it is and how many times it has been used. If this is new it should be replaced under warranty.
Apr 27, 2016 | Waring Blenders
Replacing drive side coupler on a Waring HPB300 blender. Threads don't match???
There are not normally any tricks, sometimes they are left hand thread though. More likely if the thread size is really too small then wrong part has been supplied.
Jul 10, 2015 | Waring Megamix Commercial Blender Hpb300
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
Need picture waring mbb518 blender motor
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
Nov 24, 2013 | Waring MBB518 2Speed Blender
Replacing washer underneath glass jug Waring pro blender PB20CXU
The bottom of the container should unscrew to expose the washer
Jun 27, 2013 | Waring Blenders
Jun 05, 2009 | Waring MX1000R Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Need to replace "Post and Coupling" on Waring 32BL39
Easier than I thought. Simply unscrew it. Never thought it would be that easy
Feb 07, 2009 | Waring Blenders
Waring RB75 Specialty Blender Stainless Steel 3 Speed Blender Logo
205 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
