Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
How Do You Open a Maxtor 3200 500 gb case?
I have a Maxtor 3200 500 gb external hard drive. I use it to store videos and photos.
Yesterday, when I started my computer, the computer displaced the following:
L:\ is not accessible.
The request could not be performed because of an I/O device error.
A buddy of mine told me it may just be loose cable. Told me to open it and check. My question is, how do you open the darn thing? Am I headed in the right direction?
Also, I checked disk management. It recognizes the drive but I still get the same response when I open the appropriate drive. The concerning thing under disk management is that the capacity and the percent available are the same. What's the deal? Did I loose my data?
Need help!
AlohaSunset
  • 3 more comments
  • AaroKid Nov 15, 2007
    On mine there is 2 labels, and there is no hidden screws under either!
    So how do I open the box?
    Aaron
  • Anonymous Dec 18, 2008
    i switch off my maxtor after using, could get it back on after a day. which means theres no power going through and also my computer could read my maxtor.
  • Anonymous Jan 07, 2009
    I was useing my mextor yesterday, it started off not coming up and then it finally did. Now I can' pull it up!
  • enakar Feb 11, 2009
    I have the same problem and don't know how to open the covering case.
  • Tuma21 Apr 12, 2009
    can someone please help...i tried everything...even..."How to open the enclosure You will need a long flat piece of metal.
    On the sides of the enclosure are small slits.
    If you look in the slits diagonally you will see a metal tab.
    Slide the metal tabs about 1/4" towards the ends of the case. (there are 4 slides one on each corner)
    The case will now open freely."
    this just does not work for me...
Posted on Dec 14, 2008
Remove the two visible phillips screws on the connector end of the case, (there are no hidden screws under the labels and the little squareish slot is nothing i can figure other than another vent -- then, press down on one side of the top vents and pull apart along the case halves, it disengages three crappy little small plastic latches, there are the same latches on both case sides -- start on either side, it was not easy. i was only able to open one side enough to forcibly pry open the case with my hands (nothing broke in so doing), so i'd say the design is hardly elegant, certainly not "ingenious."...
why open the case? because the green light flickers or does not glow, meaning the drive is not powered so it will not be recognized. Mine fried from connecting a similar looking AC adapter (a common IBM 12V 4A output AC power supply.) They have the same plug as the proper Maxtor 12V 2A AC supply. I'm pretty sure the higher amperage fried the enclosure circuit which resulted in a flashing or no green light - (when it works the light is steady.) Someone on this site said the 90% of the time when this happens it is just the enclosure power supply that failed, and that the fix is to remove the raw drive from the case and put into another enclosure (or connect to an internal IDE/ATA power and connector ribbon)
...but the bad news is when i put the raw drive in a good enclosure, it still only flickered, so i think 500 Gb drive is toast...well, at least i figured how to open the damn case...
Posted on Nov 27, 2007
  • blundellp May 15, 2011
    Here I just managed to get my case cover off. Here's some afterwards photo's to help other's:http://photobucket.com/maxtor3200 took a bit of force!
I've got an older 3200 USB drive that uses a completely different mechanism. After prying for an hour I discovered that the enclosure is held together by four metal strips with hooks to both sides. They are - barely - accessible through the venting slots and need to be pushed outward about 10 mm to unlock the case.
Posted on Nov 09, 2008
Unscrew the two screws from the rear of case.
Starting at the rear at the end of the first ventilation hole, push in or squeeze the top half - it will 'Clunk' - pry open the case a bit and push at the end of the next vent hole, it will clunk .. repeat down the top of one side, and then down the other.
Comes of easy this way.
Posted on Dec 17, 2007
There are 4 sliding 'fingers' that have to be pushed into the case about 1mm (to unhook them from the case) then slid towards the corners. They are tin metal and are accessible via the middle 4 ventilation slots - ingenious!
Posted on Nov 15, 2007
I've connected my externar drive in a similar looking AC adapter (but higher voltage). Then I've opened the Maxtor. Connected the disk in a enclosure but the disk was dead........
Posted on Jul 19, 2008
  • benjamin_nie Oct 24, 2010
    On 10/23/10 I stuck a small knife into the middle 4 (2 per side top and bottom) slots, fiddled around and was able to slide the four metal plates toward the extremities of the Maxtor drive. I broke a bunch of plastic in the process and in the end determined that by brute force it was possible to open the drive.
How can you open it without removing the label? cus that would void the warranty?
Posted on Jun 26, 2009
Grab the hard drive, set it under a drill. Drill a hole BE CAREFUL, AVOID HITTING THE HARDDRIVE ITSELF. After you've got a visible hole stick a screw driver in it and bent it till the case falls apart. Now just remove the harddrive from the case. Problem solved.
Posted on Aug 03, 2008
How Do You Open a Maxtor 3200 500 gb case? - 8f316f0.jpgThere are many more than 2 screws, 17 and counting. Yes, on the maxtor 4plus, they are under the label and UNDER THE sticky foot pads. There are many steps and I am stuck at this one. I appear to have all the plastic off, but can't get the metal or the metal cap off. So I have no IDE or whatever connections. I say we report maxtor to the BBB. Jude.
Posted on Mar 02, 2008
Thank you for the info, I connected another power, and seems like my hard drive is burned, I lost thousands in that hard drive, next time will not trust on maxtor hard drives.
Having same problem last night I got a I/O Device error and need to know if I
Posted on Feb 29, 2008
    Champion:
  • 208 Answers
I opened one like 2 months ago. fun .. i think under the label theres a screw.push on it till u find the hole. then poke it with phillips screwdriver... sounds like a bad drive.
Posted on Nov 07, 2007
I have a maxtor 500 gb basic desktop storage the usb pot on the hard drive went too deep into the case and its not waorking what should i do ?
I assume you mean an external drive. You will simply need to open the case (external drive case, NOT the actual HDD!) and re glue the USB port where it belongs. If the port had been soldered in place, you will likely need to re-heat the joints with a soldering iron.
Mar 25, 2011 | Maxtor Hard Drive
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
My computer will not recognize my external hard drive
the external hard drive's motherboard is burnt take it apart (this will be a little hard but it will come apart) after you take apart u will see it is just an internal hard drive in a case so either...
1) put it inside your computer as an internal or..
2) buy a new external hard drive case (that will have a new hdd motherboard in it)
after you install it either way your computer will reconize the hd and WORK i done this just yesterday.
Nov 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Computer is not detecting my maxtor onetouch III
the hard disk interface could be broken, open the hard disk case and use it as an internal hard disk as a slave in a computer to save your data
Oct 27, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
How can I open the Maxtor Basics 500GB case??
See this link:
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor formatting
i have a maxtor my computer crashed and i lost my disk how do i get my pictures back
Oct 05, 2008 | Maxtor OneTouch A01B080 80 GB Hard Drive
Maxtor Basics Personal Storage 3200
You need to open the enclosure and either put the drive in another enclosure or connect it directly to your computer.
Or you can pay to send it to data recovery people and they will get all the data off.
May 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch external 180gb
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 19, 2007 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
31,418 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
