Computers & Internet Logo
V
VINITA SAWYER Posted on May 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to measure air conditioning tonnage to square feet of hom
I NEED TO KNOW THE SIZE OF AIR CONDITIONER I NEED TO REPLACE MY OLD UNIT, SO HOW MANY SQUARE FEET TO THE TON?
Bhabotosh Chakraborty
Level 2:
New Friend:
  • Expert 138 Answers
  • Posted on May 29, 2014
Expert
Level 2:
New Friend:
Answers
138
Questions
0
Helped
27859
Points
262
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
  • Bhabotosh Chakraborty
    Bhabotosh Chakraborty May 29, 2014
    400 square feet area need 1 ton air conditioner ,and calculate your own square feet for your new air conditioner .
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
My air conditioner dwc 084 rl model does not work well, can not maintain a temperature below 70
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condense water will be picked up by the condensing fan slinger properly.
It could also mean that you are trying to cool too big an area for the size of the unit.
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
A/c seems not to working cooling down room What are my options?
Could be several factors. Let me start by saying the unit you have should cool a room that totals around 450 square feet (Approx.).
If you do not know your rooms square footage just multiply the width of the room x the length of the room.
(e.g. 20' x 10' = 200 SF)
The above 450 SF is for a room with typical 8' ceilings. This is also a "Rule-Of-Thumb" measurement, as windows, doors, insulation, and air leakages (heat gain) also play a role in calculation of heat loads. But this will get you close....
If the room is larger than 450 S.F. in size then the unit is too small for this size room.
A rule of tumb for sizing is: every 600 square feet requires a ton (or 12,000 BTU) of cooling. Again, without doing a proper load calculation on the room or area being cooled, it is hard to be exact.
The other possibility is the unit is not operating as it should due to mechanical or other issues. This is hard to specify. COuld be refrigerant levels are low, coils dirty, or filter dirty.
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
2helpful
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
4answers
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Ruud Furnace needs replacement
What part of the country?
How many square feet in the house?
Insulation?
Single pane glass?
Many factors should be considered by a professional.
However if the old unit worked OK, a new 80% 70,000 unit will most likeley replace a 24 year old 60-70% 75,000 unit.
I need to know what size central heat and air unit i need for my house
Absolutely, can you give me the following info?
Do you have ducting? If so how many vents? How many return vents, and what size? How many square feet do you have to heat and cool? Are you replacing an old unit? If so whats the old units model number and make? Are you buying the Heat Pump, gas furnace, electric furnace, or dual fuel, or Air conditioner?
Thanks a lot of questions, but extremely important in sizing your home.
128helpful
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
if this helps please vote me a fix ya
Grand Canyon Tech
Grand Canyon Tech
