Question about Porter Cable Air Tools & Compressors
Will not hold pressure above 50lbs - Porter Cable Air Tools & Compressors
  • 999 Answers
If you are saying it will nod build pressure above 50lbs: the flapper in the head assembly has broken or is leaking. Does it seem to be a lot louder than it was new? The Piston ring is worn out. Either way you are tearing down the head.
Eric
Posted on Jun 25, 2009
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Craftman air compressor
Hi
Here are a few things to check.
You may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Please take time to rate me
Posted on Aug 25, 2011
Evap air cooler
Thermostat too high, city water pressure too high (best pressure 50Lbs). Pressure regulator can hold the pressure down, replace it.
Nov 24, 2017 | Water Water Heaters
What is the proper air pressure? i know 50lbs is the max for the 2002 lexus 430sc
The proper air pressure is on the label inside the door sill drivers side but around 32 psi rear and 30 psi front
May 01, 2014 | 2004 Lexus LS 430
Pool will not back flush,low pressure
did you remove old sand did you get sand down standpipe
Jun 02, 2013 | Hayward Pool & Spa
Fuel problems
Sounds like the fuel pressure regulator is stuck in the open position.I am trying to remember if this engine(Vortec?)has a return line to the tank.If it does,try disconnecting the return(smaller) line,and use something to plug the fitting on the outlet of the fuel on the intake(Use a piece of fuel hose and a bolt_make sure you use a hose clamp,as there is 50 PSI of pressure)
Dec 31, 2011 | 1995 Chevrolet Blazer
Won't start.what is the fuel rail pressure on this engine
the fuel pressure on your car is 44lbs at idle and builds to 50lbs to 55lbs just off idle.
Dec 12, 2010 | 2003 Chevrolet Malibu
My 1995 gmc sonoma 4.3 liter vin# with a W, Has a new fuel pump, new injector spider system, it only has 10 lbs of pressure, won't start. I understand it needs 50lbs of pressure to start. Where might the...
When the fuel pump was replaced ,did the pressure and return lines get put back in the right tubes?What do you mean by a new "injector spider" system,I've never heard the term.Have you checked for bent fuel lines?Where are you doing your pressure tests from?A little more info would be most helpful,thanks.
Mar 21, 2010 | GMC Sonoma Cars & Trucks
Motor is skipping.
A burn valve will not hold compression when tryin to test a cylinder. your piston rings are worn and that cylinder is running at half power or less. Its a costly repair but your car will be runing like a champ once finished
Feb 28, 2010 | 2004 GMC Envoy
Tire pressure monitor light staying on
the dealer will have to do it its a program in the car computer that is set up to monitor tire pressure since you changed the pressure the computer knows the change and is letting you know there is a possible leak.you can have it altered at the dealer only.
Feb 02, 2010 | Chevrolet Silverado 2500HD Cars & Trucks
Air Tools & Compressors Logo
61 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
