Hi. It's most likely that the battery is completely dead - beyond resuscition if you like. Your phone might power up with the charger after removing the battery or a battery could be had for a few pounds on Amazon or ebay. Check your model
If it is not able to be charged you can still buy a couple of spare batteries with wall charger cheap from ebay or the like. Take the battery off the phone and use the battery charges directly in the wall charger.
http://www.samsung.com/us/support/ If you are looking just for the power supply then Best buy carries replacements. However, if it is an issue with the receptacle where the power supply plugs into the laptop, I would contact Samsung and see about repairs.
Do you mean picture of the charger? Try this link. http://www.google.co.in/search?q=samsung+star+gt-5233w+charger&num=100&hl=en&client=firefox-a&hs=4y5&rls=org.mozilla:en-US:official&prmd=imvns&source=lnms&tbm=isch&ei=lXYFT86nIoyqrAeC2LXXDw&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CCMQ_AUoAQ&biw=1024&bih=629
samsung gt c3303i I play my phone and it's lock now but i try all number but that's not work Please help me how di i open my lock code. And this is my IMEI Num- 353137/05/493431/3 Thankyou
well probably you have a faulty power supply do this :
>undo the back
>look for buggy or burned capacitors in the POWER SUPPLY
*this model has two power modules (Main + Sub)
>when find the bad capacitor replace it.
just in case that you need the parts numbers of the power supply's are those :
> MAIN : BN41-00521B
> SUB : BN96-01805A
you can get online just google it
Please Rate me !
Fosg'2000
First check your num lock key led if it on and off when you press num lock then your cpu gives diaply to monitor perfact. Then check your display connection from monitor to cpu. When you power up the computer pressF8 ket then enter in enable vga mode.Then go to control panel -> display->property ->settings. Then change screen resolution to 1024*768 then apply and ok . But if you still not get dispaly then
-> Open cpu cabinet. -> Refix RAM meory clean all dust from motherbord chip set . -> pull cmos cell for 15 minutes. -> Reattch ATX power supply to motherbord. -> Refix processor it is bottom of processor fan.
Please rate my solution if it help you . Thanks for using fixya.
