Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works refrigerator doesn't ge tbx-25zle
Freezer works refrigerator doesn't ,ge tbx-25zle
    Novelist:
  • 103 Answers
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
  • 351 Answers
This probably is a defrost problem, ge is very good for bad defrost elements, go to whirlpoolpartssurplus dot com and call me i can ship you them
We have water om the floor under the laft fronmt corner of our fridge/freezer . Model tbx 22pr
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Try to check the defroster heater this cause the problem;
Jul 30, 2008 | GE Refrigerators
Freezer works fine but fridge doesn't get to cold any more
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 31, 2011 | GE Refrigerators
GE Profile freezer is reading 22 degrees F. I have set it to 0 degrees and it doesn't appear to be working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | GE Refrigerators
I have a GE TBX 22Z - just recently, the refrigerator half has almost stopped working. The freezer half works fine - everything stays very cold. The bottom half, however, gets quite warm and has even had...
Push gently on the back wall of your freezer. If you hear a crunching sound resembling snow under foot or dry leaves being stepped on, you have a frost buildup. Your fan may still be working, but your entire refrigerator depends on that fan being able to draw air over those blocked and frosted up coils. The most common cause of this is a dead defrost thermostat. The second and third problems are the defrost timer or defrost heater. Spin your defrost timer (located near your Temperature control, it's in a small hole with no screw in it) till it clicks and check the freezer wall to see if the frost starts to steam and melt. If not, unplug the fridge2_bing.gif, then try disconnecting the defrost thermostat (usually clipped onto the main freezer coil at the top) and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters2_bing.gif are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 13, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
Fan runs freezer and fridge runs hot
sounds like a bad capacitor, located on the compressor.
Jul 01, 2009 | Refrigerators
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
672 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
