Question about KitchenAid KUDS24SE Built-in Dishwasher
Our Kitchenaid kuds25se fills with water but won't wash or drain.
I have verified that all the cycles work except the wash and drain cycle. I believe the pump has failed but don't know how to verify it.
    Problem Solver:
  • 6 Answers
I would check the check valve ....i had the same issue and the info within below link got be up and running again
http://fixitnow.com/wp/2008/11/14/older-whirlpool-kenmore-dishwasher-wont-drain/
Posted on Jun 25, 2009
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
Wash cycle runs, drains, but will not fill up for rinse cycle
The water inlet valve solenoid needs to be replaced , they are made together.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
Dishwashers Logo
688 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
