Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Hp clj 2550 is printing blank pages only! - HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
  • Kevin Hughes May 11, 2010
    even if you print a supplies status page directly from the printer??
webxcreation
  • 4 Answers
SOURCE: prints extra blank page for every one page of printed material
I believe this will solve your problem. It did for me.
delete your printing device and reinstall,
when it asks for your driver, let it search for it.
When your options come up, find "HP" then look for "HP Officejet 7200"
DO NOT install "HP Photoprinter 7200".
This should take care of it.
Good Luck!
Posted on Oct 26, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp 1320 prints blank
I would need more information on the same.
Is the printer printing blank pages, while printing configuration, internal test pages, or is it happening while printing from PC.
Please advise.
- Nikhil
Posted on Nov 03, 2008
yooperbud
  • 8637 Answers
SOURCE: HP photosmart 7150 - looks like it's printing - pages blank
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
PeteG0429
  • 34 Answers
SOURCE: Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Posted on Apr 02, 2009
PeteG0429
  • 34 Answers
SOURCE: C7200 prints blank page between each printed page
Here's a solution. Hope it helped!
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
BLANK COPIES FROM KM 2550
first chek dev unit toner? pls insert toner 1087+ 1087+ 130 set dev enter ok then 10 mnt wait and check drum and dp closing time corect sitting or chage edge of dp unit you cleang time smothing wrong?? comng blnk copy
Aug 03, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
I have an hp laser printer 2550. all os a sudden
What has wrong is the toner cartridge holder has jumped a tooth and thats what is causing it. It is a easy fix but very hard to tell you over fixya. Steven 818-888-0006
Mar 12, 2010 | HP Color LaserJet 2550n printer + HP Color...
Hp clj 2820/2840 alle-one printer. print yellow page oly
we had one in our company for 3 years.....once it starts acting wacky its time for it to go. an hp repairman told us it was the main motherboard inside. it would have cost us 350. we just bought a new printer different series instead.
Mar 01, 2010 | HP - PRINTERS - CLJ 2820 AIO 20/4PPM 96MB...
Blank print coming for hp clj 2840
hi
pls.give me the solutions for thise problem
May 23, 2009 | HP - PRINTERS - CLJ 2820 AIO 20/4PPM 96MB...
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
How to print a blank page HP 2550 Laserjet
Open notepad, select Page Setup under the file menu and delete the entries in the Header and Footer fields and click OK. Also press enter or space a couple times so that there is something to be sent to the printer - then print!
Dec 30, 2008 | HP Office Equipment & Supplies
HP 2820 CLJ, ONLY PRINTS DOWN ONE SIDE
ok typical carousel misalignment
http://www.fixya.com/support/t400576-printing_right_side_only#SameProblemContinued
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
1,111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
