Question about RCA RCU600M Remote Control
CLARIS WHAT IS THE CODE TO USE FOR SETTING UP UNIVERSAL REMOTE FOR CLARIS TV ?
5 Suggested Answers
SOURCE:
aprmaejun
  • 97 Answers
SOURCE: RCA RCR311W Universal Remote Code for LXI TV
From what I can tell, it could be any of these codes:
1000
1006
1048
1049
1062
1072
1073
1100
1109
1130
1162
1181
1203
1212
1233
I used this website:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
Posted on Jun 12, 2008
the q guy
  • 393 Answers
SOURCE: need rca universal remote rcr 312w.code for ilo
try this website if you dont find the codes let me know i will find them for you
http://www.xdiv.com/remotes/
Posted on Apr 23, 2009
  • 233 Answers
SOURCE: help with GE universal remote control need code for magnavox TV?
Try this link and select the RCR451 and try the codes for it, if they do not work try the one for the RCR 460 one. Just scroll to the bottom of the page and look for the word next, click it and you should see the 460 on the bottom left.
Posted on May 30, 2009
digritz
  • 530 Answers
SOURCE: RCA Universal Remote Code For A Trinitron Xbr Tv
There are several RCA universal remote models. With out your specific model # I can only give you the most common code. 002.
You can also try the steps below to use the internal code search mode if your remote has this feature.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Oct 23, 2009
What is the code for a claris tv on a universal remote
Check the manual, there is no standard for remote codes.
Dec 13, 2014 | Televison & Video
Need code setting for ge universal remote control 24993 for sony tv
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Sep 24, 2014 | GE 24993 4-device Universal Remote remote...
Directv Claris remote volume
Hello
Just check the sites linked below. . Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. I'm sure that there the solution to your problem. By the way, how will you send 50 Dollars you have promised here. Do not want anything my friend. Check these sites. One among them have so many posts. Check it patiently. There is it. If not, inform me. OK.
http://electrohelponline.blogspot.com/
Apr 23, 2013 | Directv Televison & Video
What is the code for a claris tv/ direct tv remote
We need the code for Claris? the Code was not in there.
Feb 12, 2013 | Televison & Video
What's the code for universal remote?
sir i have onida 21'' tv thi tv vertical line smoll so i need adjest for v line. please tel me fectery setting code
Jan 19, 2012 | Televison & Video
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
May 10, 2009 | Universal Remote Control GE174Universal...
Code
need help with setting my remote to my tv
Dec 10, 2008 | RCA 3-Device Universal Remote with...
RCA RCU600M Remote Control Logo
208 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
