Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Pressure washer wont hold pressure
My pressure washer will only hold high PSI for a few minutes at a time.
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Posted on Apr 02, 2010
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
  • 2841 Answers
SOURCE: New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Posted on Apr 25, 2010
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Low water pressure coming out after pump is on
Check skimmers, pump strainer basket and filter pressure. If filter pressure builds. time to backwash the filter. Also, the impellar on the pump might have debris in it...
Jun 06, 2010 | Hayward SAND FILTER, PRO SERIES
Engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Jun 01, 2010 | Honda Pressure Washer PSI 3000
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
388 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
