Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Accidentally plugged into 220 volt outlet
I'm in the military, stationed overseas. My housekeeper put a converter plug on our brand new Electrolux and plugged it into a 220 volt outlet. Needless to say, it appears to be dead as a door nail. Is there a fuse that could be replaced? Or is the motor toast for sure? Any suggestions? Thanks!
  • armymomof4 Feb 19, 2008
    I am not sure what was done, but the small appliance repair shop here fixed it good as new for $30.  :)
    President:
  • 1,673 Answers
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Posted on Feb 16, 2008
    Novelist:
  • 97 Answers
On the main control board there is a fuse, which for some reason is actually hardwired to the board, meaning that the entire board has to be replaced when the fuse blows. I'm a repair tech for these things, and they go bad constantly, so it may or may not be related to being plugged into the 220V circuit. I would take it in to a warranty station and let them make the determination.
-R
Posted on Jul 29, 2008
How do I convert a kirby ultimate G from 110V to 220V
You can't. The Kirby draws too many amps for a step down transformer.
Ask Kirby direct if they can convert your head to 220V. click Support - Contact
Kirby Ultimate Vacuum Kirby Models
Nov 10, 2016 | Kirby Vacuums
Our rainbow e2 black type 12 vaccum was meant to be used on 110v and was plugged into a 220v, what part needs to be changed to convert the machine to work with 220v
nothing that I can guess at but changing the motor to a 220 . might be more cost effective to purchase a new vacuum cleaner .or use a 110 convertor for your outlets
May 22, 2016 | Rainbow Vacuums
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
Nothing happens
it could be the wiring coming from the vacuum itself you might have to change it.can be brought at any electrical wire store have you checked the plug wiring is it all intact or has some came out from the terminals?
Apr 06, 2014 | Electrolux Z4735AZ Gazelle 1900W Upright...
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
My daughter plugged my 110 volts dyson dc14 into a 220 volts outlet. It no longer works - can it be repaired?
After checking with Dyson, it appears it can be fixed but depending on the age, it might be more cost effective to just buy a new one. There are not a lot to the dyson vaccums to repair. Plugging the vac into double the voltage would have fried the motor and that will need to be replaced. There is not reset or surge protector. With shipping and replacement of the motor, we would recommend a new vac. Good luck and sorry!
check out this web site for some possible other fixes before buying a new one:
http://www.dyson.com/support/help.asp?model=SUP-DC14&article=2
Mar 23, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
How to use 220 volts sewing machine to 120 volt plug, were can find a transformer?
If the sewing machine came from a forigen country, Check radioshack. They might have an adaptor there. but be ready to spend some $. but if it is an industrial sewing machine, have an electrician put in a 220 volt outlet. Don't cheat. Your home will be put at risk from fire.
Aug 12, 2010 | Vacuums
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
755 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
