Question about Home
In sink erator badger5 is leaking from the bottom
    Problem Solver:
  • 6 Answers
If the seals dry out the disposal will leak. This is caused usually from non-use of the sink as if the disposal sits dry for an extended period of time without water going through the disposal. You can buy new seals and rebuild it, however the time and parts don't warrant unless you want to do it yourself. if it is more than 2 years old or you do not know how old it is you are better off replacing the device.
Posted on Jul 04, 2009
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The gasket coming out of bottom of our sink erator was leaking and spewing. when we replace the washer before bolting on the gasket do we use plumbers putty?
Plumbers putty is for setting sink basket into sink.
I use rectoseal on all tubular washers and joints,
Smear it on thick and then assemble parts, and rectoseal ensures nothing will leak.
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger5 disposal leaks out the bottom
If it is actually leaking out the bottom of the disposal, and not from under the sink, or the outlet of the disposal into the drain, or where the dishwasher discharge enters the disposal, then it could be the seal leaking. If so it just isn't worth fixing, buy a new disposal. They are easy to install for a DIYer and not that expensive. But check for those OTHER leaks first.
Jul 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Home Logo
386 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
