Question about Sony KV-32S36 32" TV
Tv pic flickers
The pictureon my sony tv flickers on and off at about 1second intervals. i've been told the picture tube is going. can there be any other reason for this? thank you.
  • 1,694 Answers
Bad pix tube common on " S "and " V " line SONY,
I agree, pix tube going bad.........
Posted on Nov 05, 2007
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
After the tv is on the picture starts going red until it turns totally red.
It sounds like a bad crt on the red picture tube, but impossible to tell for sure w/out seeing it. These sony's have a lot of trouble w/ the tubes and crt's.That would be the first thing I would check. From the front of the set, you can gently tap the neck of the red pic. tube w/ the handle of a screwdriver while the set it on, and watch to see if the set flickers or if the red changes. You may want to let a tech take a look at it and give you an estimate. If this is the problem it will probably be fairly expensive to repair. You may be better off to get a new set.
Jul 29, 2010 | Sony KP-51HW40 51" Rear Projection...
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
Mar 28, 2008 | Sony KV-35S45 35" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-32s26 Out of Focus, Green, flickers off and on
I regret to tell you that he is probably right. The problem is the trinitron picture tube. Sony advertised it with such high esteem for years and wouldn't doubt that they would do that. The phospher is burned out in the tube and the guns (red, green and blue) are weak and the focus electrobes in the tube are also weak although Sony made it a lot different that any other tube requiring extra circuitry. There is no fix for this. If you could bypass the blacking out you would still have the bad out of focus picture problem
Jan 01, 2008 | Sony KV-32S26 32" TV
Snapping noise and flickering pic when set is first turned on
The hi voltage cable a red wire with gray cup that its attached to the picture tube needs to be sealed , that can solve the problem. 40.00 dls depending on the tech . dangerous to do without the knowledge ,picture tube need to be discharge before, try to seal to avoid accidental hi voltage discharge . if you need more help let me know
Jun 14, 2007 | RCA F27669 TV
Picture flickers off and on
I would try adjusting the screen control on the flyback. The flyback can be easly located, find the red wire attached to the top of the picture tube & follow it down to the flyback. on the flyback you should find two controls, one screen & one focus. you sould be able to read the words above each control, only adjust the screen one. slightly increase the control till the picture stays on, if you turn it too much you will get small white lines going across the screen. Now if what i have told you fixes the set, then it is only a tempoary repair. could last days or mothes, maybe years. if it starts to happen again later the set will have to be replaced. this is a sign of the picture tube starting to get a weak. ALSO DO NOT PLAY WITH THE RED WIRE IT CARRES VERY HIGH VOLTAGES EVEN WHAN UNPLUGGED FOR DAYS.
Oct 30, 2006 | Sony FD Trinitron KD-36XS955 36" TV
Televison & Video Logo
205 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
