Question about Saeco Milk Island Automatic Frother -
Saeco milk island - no froth
I have a saeco milk island and it is only just heating the milk, no froth, what is the problem. I have cleaned all of the parts but still no froth! The coffee machine is a saeco taleo touch.
  • 14 more comments
  • Anonymous Dec 27, 2007
    I am having the same problem - no froth from the milk island. It worked well for two weeks before it stopped frothing.
  • mneray
    mneray Jan 20, 2008
    Me too. Like one of the other people, it started after 2 weeks. The first two weeks the milk foam was far better than I was expecting. It was fantastic. My machine also has a clunking pump noise for either steam or milk island. This may be normal.... does anyone know?
  • marnei Jan 21, 2008
    Yes have solved the problem. You need to pull the milk island apart totally and rinse it. Leave all parts out to dry overnight on a paper towel, especially the little black plug that comes from on top of the milk island (after you take the holder off). This little black plug is the frother and if it stays moist it will not froth. You do not need to pull the black plug out of the holder just rinse it and place all parts of the frother on a paper towel to dry completely.
  • mneray
    mneray Jan 21, 2008
    thanks Marnei. I already tried that but maybe I should try it again. You are saying that I need to take apart just the milk island -- but I don't have to take the milk island off the unit from the bottom right?
  • Pepet Jan 26, 2008
    Same problem, too.
    I've tried to clean and dry every little piece, and it didn't work.
    So I went back to the store, and they gave me another Milk Island, wich started working perfect.
    But only worked OK for a week...
    I've searched over the Internet, and this is the only place that somebody else has the same problem...I'll bookmark, and I'll be back for solutions.
  • CoffeeN Feb 27, 2008
    I have the same problem. The froth was excellent to start off with. Then suddenly one day about 2 weeks after we got the machine, the milk gets hot but no froth. Tried different milk types etc......please help
  • Anonymous Mar 13, 2008
    I thihk I've fixed it. As marnei says, this is a cleaning problem. You must be sure that the plug he says, and the hole in the holder must be perfectly clean.
    To clean that, I use a thin brush.
    If you do that usually, you'll get a perfect froth.
  • Molly Bolt Mar 19, 2008
    I too have this problem...
    I have cleaned as per solutions offered here...can you tell me whether or not the grey valve needs to be put back in place in some specific fashion ie: parallel or perpendicular to the two slots on top?
    Thanks very much
  • marnei Mar 20, 2008
    The dark grey pointed rubber plug goes in one way by poking it back in.
  • mneray
    mneray Apr 20, 2008
    I've given up. Two weeks after getting a new frother, I got the same problem. Cleaning, rinsing and drying the milk frother is all more work than simply using the steam wand. Frothing milk isn't supposed to be this difficult. This is too bad because the machine is fantastic otherwise and I would still recommend it. The milk island has a serious deign flaw and Saeco should fix it.
  • Anonymous Feb 01, 2009
    hello capp-lovers, i too, experienced the flat froth, broken base rubber tip, missing carafe problems. for what it's worth, saeco came out with a milk island version 2. probably going to buy it since there's no way of fixing the broken base rubber tip and will issue a report.
    canadian coffee lover!
  • Molly Bolt May 11, 2010
    Hi there Guest Provider of Solution #2
    Can you please see my specific question above re: alignment of grey rubber plug...
    Thank you so much...
  • Anonymous Mar 12, 2014
    how to froth milk with delongi bco260b
  • Anonymous Mar 17, 2014
    Taleo Touch not getting power no display
  • Anonymous Mar 20, 2014
    its not frothing the milk
  • Anonymous Mar 24, 2014
    Arm keeps falling off clip does not work?
I found that to make a good seal between the milk island and the base, it helped to wet the nipple at the base slightly just before putting the milk island on. This seems to help it make and keep a tight connection. Prior to doing this half the time when we would put the milk island on the light would turn to red shortly after we started frothing.
Posted on Jun 06, 2009
This site has been very helpful as I have run into the same problems...the unit worked for about two weeks and then only hot milk - no froth. Took the milk island back and they gave me a new one - again it worked for about two weeks and then no froth. Totally frustrating. I look up the problem and found this site - I was happy because I found I was not alone in my frustration. So I completely took the milk island apart (the components in the carafe) there are 5 components - I don't know what they are called but there are 5. I washed all the parts and dried them. Then I looked for small holes to clean ( I used a flash light) and found 4 small holes (pin size) I used a toothpick to clean these holes. I then reasembled the parts and the unit worked as if it were new. It continues to work...we just have to spend the time to clean all the parts including the holes. (I think that if the holes become clogged with milk residue it will not make the froth).
As you can tell I'm not great at explaining this - the important part is to clean all the pin sized holes - there are 4 of them. Find them...clean them and it will work. Hope this helps.
Posted on Jul 07, 2008
I've given up and returned it the unit. What I thought would be a time-saver turned out to be a huge cleaning problem. It's just easier to froth it the old-fashioned way. When Saeco redesigns the milk frother to fix this problem, I'll be one of the first to try it... till then, my paranello works just fine.
Posted on Jun 09, 2008
Solution #2 is the correct way of cleaning it. Brought mine about a month ago, April 2008, 2 weeks later, all I got was hot milk. Took it back, and basically they cleaned it.
You have to clean the 'black triangular part with the rubber nozzle'
1) pull out the jug from the bracket
2) on top, pull off the triangular part
3) very light rinse it, DONT loose the rubber nozzle
4) let it dry completely
5) give it a sharp blow to purge any moisture/water which is inside the rubber nozzle
thats it.
Done it 4 times now and still works fine.
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
Posted on Apr 20, 2008
I agree with the poster that the key item is the little black plug (referred to as the valve in the supporting documentation). My milk island frothed beautifully for 2 months before gradually decreasing until I was getting just hot flat milk every time.
The valve has a dark grey pointed rubber plug which is possible to pull out and clean, and is fitted back in the hole by poking it back in. But what I found made a huge difference were the two slots/holes in the top of the valve piece. In my case they were clogged up (invisibly) with dried milk. As soon as I used a needle to unclog and clean the holes under a running tap, it got back to frothing again.
Whenever I use the milk island, I make sure I rinse and clean all parts immediately after use, leave them to dry, and before putting together again give the two holes in the valve a brief hard blow to clear it of water. The whole cycle takes about 30 seconds at most.
Posted on Mar 13, 2008
I tried cleaning the thing throughout, and drying it on paper towels, but still no froth. Luckily, I bought the machine from a reputable dealer with superb integrity. He fixed the problem for me by returning the milk island and getting me a new one. It works perfectly now.
Posted on Jan 27, 2008
If you are getting steam out of the wand I suggest you practice and work ha and to learn how to froth up the milk. The machine does not froth up, it is the operator who does. You basically need to keep the wand just below the milk level and keep moving very slowly up and down always trying to stay below the milk level. If the container is wide you may need to swirl as you moving.
Mar 14, 2013 | Saeco Coffee Makers & Espresso Machines
Saeco Milk Island
I dont think that there is a such diagram on the web.It is easier to see how it is inserted looking an assembled appliance.
Feb 14, 2008 | Saeco Milk Island Automatic Frother -...
It doesn't froth properly
Trial and error solved the problem. The milk island is great but needs REGULAR cleaning. In order to clean properly one has to take apart the milk island and clean all rubber components of the dried milk that can and will accumulate. The most important cleaning taking place in all little holes as they are most likely to clog from the dried milk.
Jan 30, 2010 | Saeco Milk Island Automatic Frother -...
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Steamed milk is not coming out
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Mar 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Aug 29, 2008 | Saeco Talea Giro Espresso Machine
Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Jul 11, 2008 | Saeco Incanto Classic Espresso Machine
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Too much froth
Does this happen after you make several froths or the first time you start the machine? Try removing the panarello and froth milk that way then see if this is happening too without the panarello. I found that panarellos are great as a "quick learning to froth?- but they do have the tendency to froth milk too much without heating it up ( to the temperature that you like).
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Milk Island Automatic Frother - Logo
1,476 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
