Question about Whirlpool LER4634J Electric Dryer
Dryer does not heat
I set the timer.....the dial does not move during the cycle , and the dryer does not heat
  • 351 Answers
When your dryer does not heat the timer will not advance, check the heating element and the thermal cut out kit
Posted on Jun 25, 2009
Timer switch faultynonnwhite knight 44 aw . Will work for a couple of months then not, then start working again for a while then not?
Motor in timer is stopping heats up stops needs new timer
also check even heat board or cycling stats if these stats do not open timer will not move also check for vent restrictions if dryer over heats can also be a issue send me exact model number or picture of Tag will be bedder
Feb 19, 2015 | Abbaka White Knight 44AW Electric Dryer
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Sep 21, 2014 | Dryers
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
Sep 30, 2009 | Maytag Dryers
I have a whirlpool dryer that doesn't heat up and it will not stop running and the dial doesn't seem to move
Hi, The timer will not move if there's no heat when you have it set on the automatic cycle. I need to know if this is electric or gas. Please get me a make/maodel 3 so I can help you through this.
Thanks
Vic
Jul 18, 2009 | Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Mar 16, 2007 | Candy CIV60 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
