Question about Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV
Pride hurricane pmv just replaced batteries everything was fine went up and down the driveway (flat surface) and it stopped working
  • 175 Answers
Are any of the lights coming on? If so, are any flashing, and if so, how many times or is it constant? Check to make sure the freewheel lever is not bumped which will cause a no-go status. Put in freewheel and place firmly back in drive (located at the rear of the scooter).
Go back in and make sure all of the snap connections are tight. Undo them and redo them, don't rely on a visual inspection. Check the circuit breaker; push it in to reset. If it has tripped, you will feel a click when you push. Check all the fuses.
Posted on Aug 28, 2009
Where can i get brushes for pride hurricane in uk
I would contact pride or a service centre as if you put the wrong grade of brush in the motor you can damage the comm and motor.
The motors are not cheap.
Mar 03, 2015 | Pride Mobility Products Hurricane PMV...
Speed control on Pride Hurricane
hi, the speed control could be faulty, see if you can spray some Wd40 or contact cleaner in the gap and see if that improves things...is it the one with the snail , rabbit speed sign ?
one bar on the indicator does imply low battery power ...is it flashing ? if it is then that's a fault condition
Regards
Rob
www.gewizrepairs.co.uk
Dec 23, 2014 | Pride Mobility Products Hurricane PMV...
Where is model number located
hi, it's normally located on the seat stem between
the two batteries
Regards
Rob
Mar 28, 2014 | Pride Mobility Products Hurricane PMV...
Scooter keeps stopping randomly. The battery level near to the speed lever drops quickly to red, scooter stops. Turn it off then on again and fine for a bit - then same happens?
These units are 24 volt systems. If the voltage at the controller drops below 18 volts the controller will cut out. Shutting the unit off and back on resets the controller. Since your battery gauge is dropping into the red when accelerating your batteries are suspected to be bad. If the batteries LOAD test fine then check your battery harness and circuit breaker wiring for a loose and / o r hot connection after riding it.
Oct 28, 2013 | Hurricane Pride Pmv Mobility Scooter Candy...
I have a Pride Mobility Hurricane PMV, None of the left side signals, or parking lights work. I think I have it down to the console board. I have 12 volts going in but nothing when I activate the left...
Hoping your problem is in the wiring to and from , or the light itself , usualy when the board goes , nothing works... make sure you test every contact point for juice to and from , before you discard the possibility...!!!!
Jan 05, 2018 | Pride Mobility Products Hurricane PMV...
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
I have a Jazzy 1122. Is this a gel-cell battery I can take on a c
I think they will say its to big. They will be ok with a Pride GoGO
May 19, 2010 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV  Logo
183 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
