Question about Hotpoint Refrigerators
Can't find out what the part # is for the water valve for a Hotpoint side by side refrigerator ice maker / water dispenser. model # of refrigerator is GSX22GRZ
  • wade_bowman Jun 27, 2009
    It may not be a good model number now but it's my model number and I've used it to order parts in the past. The model numbers I found on line were not always precisely the same but there differed by only a letter or two at the end. Now, I can't find anything even similiar.
  • 351 Answers
Tried to look that up for you not a good model number call whirlpool parts surplus dot com and ask for mark i can get it shipped to you
Posted on Jun 25, 2009
Ice maker not filling door not dispensing water
Make sure the temps in the fridge aren't cold enough to freeze the filter... Water valves rarely fail at both solenoids at the same time, so be sure the water supply is turned on and that the water line is not kinked (bent in half) behind the machine... Hotpoint Refrigerator Water Filter MWFP , Hotpoint Refrigerator Water Inlet Valve WR57X10032
Aug 02, 2016 | Hotpoint HSS25GFP Side by Side...
Ice maker stopped making ice
The ice maker not making ice.In this case the water passing line and water valve needs to be inspected.--
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Hotpoint HSM25GFRSA
The water is not working, but ice dispenser is, the make number hss25gfpjww
Clogged water filter or faulty water valve. You have a dual water valve on that unit which explains why the ice maker is working and not the dispenser.
Feb 23, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water no longer dispenses for drinking
Is the water still being supplied to ice maker? Could be 2 things water line froze in door or water valve side supplying the door is out.
Mar 02, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Not making ice
check to see if the water line is frozen where it enters the freezer, this is the most common cause if the water valve is ok.
Sep 09, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Open Questions:
Refrigerators Logo
106 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
