Question about HP Deskjet 3915 InkJet Printer
Says no paper but there is some in there
What could e wrong?
  • 1,800 Answers
Try to unplug it and plug it again and see what it gives after ta!
Posted on Jun 25, 2009
Blank printing
The posibility is you are using wrong paper or the right paper wrongly. Make sure you are using a thermal paper and it is facing up because it only prints on one side
Mar 28, 2014 | Sharp XE-A207 Electronic Cash Register
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
When i try to print its pulling the paper in wrong, and then saying paper jam whats wrong?
Maybe the paper loading.Try this:-
  • Remove the previously stuck paper and turn the printer off and on.
  • Extend the paper guides by pressing down the paper adjustment lever.
  • Now load the paper making sure it goes into the center of the paper support and then adjust the paper guides by moving the lever up or down.
  • Make sure the paper guides rest against the edges of the paper.
Hope this helps.Thanks!
Please rate this answer.
Nov 04, 2011 | Lexmark X5650 All-in-One InkJet Printer
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
Keeps giving me the error "Wrong paper Size"
The paper setting is either set to a differant paper size. In which case you can adjust this in the settings menu of the printer on the computer.
Or. You have the wrong paper tray inserted.
Aug 24, 2010 | Dell 924 All-in-One InkJet Printer
Wrinkling Laser Paper
Sounds like something is either wrong with the rollers, something is stuck in there or you are using the wrong type of paper.
I suggest you take a peek inside there and see if there is anything noticeably wrong inside. If not then look up what type of paper it needs.
Jul 10, 2009 | Xante Accel-a-Writer 3N Laser Printer
Printer says wrong paper
hi annette.. when you print a photo pls try first to check the properties maybe the paper settings are not fit on the paper pack you said... thank you...
Jul 09, 2009 | Kodak EASYSHARE G610 Thermal Printer
Machine telling me wrong paper size i have reset and reloaded but not working
Check the guides in the paper tray to make sure they match up to the proper position for your paper size. If for instance the paper tray is set to A1 by accident and you are using letter paper, then you request to print on letter sized paper the printer will think it doesn't have letter paper available and will ask for some. The position of the guides in the paper tray are what tells the printer what size paper is in that tray. Otherwise your paper settings in the paper meny are wrong as this can override the paper tray settings, check them to make sure they match the paper size in the trays also.
Jun 17, 2008 | Brother Office Equipment & Supplies
Wrong paper size message
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Apr 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Deskjet 3915 InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
