Question about Hayward EC-40 DE Pool Filter with pump
Hayward eC-40 pump losing pressure very fast
I have the EC-40 It is always giving the same problem every year when trying to start it up. I put the right amount of de powder and the pump has great pressure but within an hour there is no pressure. Why am I having this problem every year?
  • 4 Answers
A better way to clean the filter tubes in the EC40 is to remove the filter tube assembly and soak it in a 5 gallon paint pail that is filled with a solution of water and a 20% muriatic acid, available at hardware and home center stores. Be very careful handling the muriatic acid. Don't splash it around.
Mix it in a 1-to-1 ratio with water and soak the assembly for at least 8 hours. Keep the soaking pail out of the reach of kids and animals.
Remove the assembly, properly dispose of the acid mix and refill the pail with clean water. Soak again for 3 to 4 hours, then reassemble your filter.
Some pool guys say it isn't necessary to soak the tubes in clean water because the muriatic acid will not harm the pool water and will reduce the pH if it's too high. I've always soaked them to be safe.
This is a link to the Hayward manual that describes the process:
www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Posted on Jun 30, 2009
  • 93 Answers
Your filter fingers inside pump are dirty you must take out the the filter assembly wash off with a hard spray from hose to clean the fingers off if you have a bump handle open drain plug on filter and bump out de reassemble start with just enough de to coat fingers less than what it calls for make sure pool is vacumned
Posted on Jun 25, 2009
  • james aurienne Jun 25, 2009
    your filter fingers inside pump are dirty you must take out the the filter assembly wash off with a hard spray from hose to clean the fingers off if you have a bump handle open drain plug on filter and bump out de reassemble start with just enough de to coat fingers less than what it calls for make sure pool is vacumned
De is going back into pool and not stiching to the fingers
there is a tear in a element or not put together correctly
Jun 01, 2012 | Hayward EC-40 DE Pool Filter with pump
My Haward perflex EC-40 filter allows DE and dirt back into the pool whenever we start it up or vacuum.
There's a hole in the filter allowing DE and dirt to pass. Find hole and repair or buy new. I just bought new grids off of ebay, great deal. I payed $112 for complete set by Unicel and saved over $100 My filter is a Hayward DE4820
Jul 08, 2011 | Hayward EC-40 DE Pool Filter with pump
Water in ec-40 pressure gauge
Water in the pressure gauge indicates a faulty gauge. It will need to be replaced. They usually run $10-15.
Jun 12, 2011 | Hayward EC-40 DE Pool Filter with pump
I bought a used Hayward Perflex Extended Cycle DE Filter Model#EC45 I have to keep backwashing it, it flows heavily back in the return but it only flows good for a little while. What do I need to do? It...
Here is a link to the hayward manual. Be sure to follow the pre-coating insturctions carefully.
Use only the swimming pool grades of
diatomite, such as:
CELATOM . . . . . . . . . . . Eagle-Picher Industries, Inc.
AQUA-CEL . . . . . . . . . . Johns-Manville Products Corporation
DICALITE 4200 . . . . . . . Grefco, Inc.
WITCO . . . . . . . . . . . . . Witco Corporation
The EC-50 filter uses a 5 lb. (2.3 kgs.) charge of diatomite (D.E.)
Here is a link to the hayward manual for a EC-50 I think its almost the same as the EC-45
http://www.haywardnet.com/products/manuals/pdfs/manual10.pdf
Jul 01, 2010 | Hayward EC-40 DE Pool Filter with pump
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
I have the Hayward EC-40 Filter, my problem is the DE is getting into the pool. What would cause this?
Broken/torn grid, o-ring bad in the housing by the grid assembly or grids not in manifold properly. Backwash, open the filter, remove and inspect the grids (the plastic bases too).
Jun 05, 2010 | Hayward EC-40 DE Pool Filter with pump
Jet Pump stops after three starts of 20 minutes each and it doesnt want to start back again until the next day or after a few hours
check motor with hand after it stops for excessive heat. Thermo coupler shuts motor off if overheating, to protect windings. Bad motor bearing can cause overheating, if so should hear bearing noise when running.
Also check start capacitor, by removing and checking with ohm meter, or plug in oposite terminals of capacitor to charge. Place rubber glove on hand, and contact two oposite terminals with screwdriver should produce a small spark.
Nov 15, 2008 | Hayward EC-40 DE Pool Filter with pump
Hayward EC-40 DE Pool Filter  with pump Logo
1,290 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
