Question about Dell Inspiron 6000 Notebook
It was working fine and then went off. It would not power up.We were traveling in the car using a Radio Shack inverter for powering the laptop. Any ideas?
  • 1 more comment
  • thsims Jun 25, 2009
    It was on my lap, I was wearing shorts, warm to my leg but not hot. Unfortunately I was on my cell phone when it shut off and I did not notice what happened. I was using a new $40 inverter from Radio Shack at the time, so I cannot say if the problem is with the inverter or what. The inverter is one that one end goes in the DC outlet and the other end has a DC outlet and an AC outlet. I have tried charging the battery but doesn't help. just a little more info for you.
    Also, the laptop is a Dell Inspiron E1505, not 6000. sorry,
    Tom
    I used a digital volt meter. the inverter was giving off 91 volts. Probably the culprit of the problem...???...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
If the computer overheated, it could have shut down. If the inverter broke, it could give invalid voltages overloading the computer and possibly shorting the motherboard. I would have a repair shop give you a estimate, it should be free. Then post a reply and i wiil walk you through a process to repair the computer (if applicable)
Posted on Jun 25, 2009
Replacement Power Supply AC Adapter Sharper Image SI601 S1601 51601 Travel Sound Soother 20 with LCD Alarm Clock your problem?
I also am looking for a replacement power AC adapter cord for a Sharper Image SI601. I tried a radio shack replacement, and it works about 50% of the time.
Thanks!
Chris
Aug 07, 2012 | Sharper Image Travel Soother 20 Clock...
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Have a pro-97 with power probems. I pluged an external power into the unit with battery pack installed. Now have no battery power. What can I do?
first of all I have this radio, and i bought the power cord from radio shack and rechargeable batteries. i left the radio on charge with the yellow battery holder with the right batteries in it in the unit some how there was a power surge and now i cant use the DC power plug but it works fine on batteries so open yours up take out the batteries out and smell if it smells burnt take it to radio shack they can fix it
Jul 08, 2010 | Radio Shack Pro-97 Handheld Scanner
I'm a senior citizen. I will be traveling in my old motorhome. I want to have access to my computer with printer at all times. Do I simply buy a laptop with printer that has WIFI? Do I have to pay a...
If you want to have Internet access while you are travelling, then I suggest you get a laptop with a 3G USB wireless adapter (this uses the existing mobile phone network) with an Internet Service Provider that can give you the coverage in the areas you want to travel.
I suggest you get a printer that connects to the laptop using an USB cable.
I also suggest you get a power inverter to convert 12volts to mains voltage so you can use your laptop away from mains supply.
or
You can a 12volts power converter to the voltage requirements of your laptop instead of a power inverter.
Jul 16, 2010 | Dell Computers & Internet
My microwave just went dead...like a fuse blew...outlet is ok..tried the microwave in another outlet nothing for power ....nothing on the microwave
there is a fuse in side the microwave on the control panel side. it is an odd looking fuse that you can find at Radio Shack
Mar 11, 2010 | Electronics - Others
For use during an extended power outage, where of course you wouldn't be able to recharge the battery after it drained initially, I'm wondering if anyone has tried using a 12 volt lead acid rechargeable...
You simply need a DC - AC Inverter, these can be obtained from somewhere like Radio Shack, or the like, pretty cheaply. These convert 12V DC into 115/120V AC (Some are 24V - 115/120 V) for use with your household appliances. You can get them from 100 Watts to over 1 kilowatt (!000 Watts) They can be used on almost anything at all, except things with big motors in them. Then you can simply plug the AC adapter into the inverter and you are good to go. not having to worry if your laptop is getting correct power.
Often the DC input into a laptop is between 14 Volts DC to 22 Volts DC and a high current too, up to 5 Amps. So the inverter is your best option.
Anyway you would need to use at least TWO 12 Volt batteries and then you would have to make it the exact voltage the laptop needed.. if it was say 19V then you are still going to have to find a way to drop the 24 V to 19 V, anyway so.....
Feb 03, 2010 | Haier HLT71 7 in. Portable TV
Can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974, and inverter is a roadpro 175watt/140watt constant with overload/overheat protection built in? the power...
you dont need to buy anything from radio shack, the inverter that you have will be just fine. i have used smaller and im sure cheaper inverters with no problem. i keep my company laptop constantly plugged in and charging all day everyday running service calls.
Dec 17, 2009 | Toshiba Satellite L305D-S5904 Laptop
Looking for a power cord
Hi guys,
Had the same problem yesterday. Went to Radio Shack and picked up a universal power adapter (Model 273-1696). It can be set for 6V and will draw the required 2000mA. Box does not include the right size plug, but the salesman gave me one that fit for no extra charge. Cost 32.99. Everything is working fine now.
Jul 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Car power adapter for portron pdv768
I went to Wal-Mart and purchased a Phillips Power Inverter that provides AC power from any car outlet. Just plug the AC power plug into it and then plug into the lighter plug socket. It solved my problem....It costs $19.99. Hope this helps!
Jun 21, 2008 | Protron PDV-768 Portable DVD Player
Dell Inspiron 6000 Notebook Logo
Alun Cox
