AC motor not starting
1978 Coleman Mach EL RV Series. Tujrn control switch on and motor tries to start up but only get loud huum. Took cover off top and gave fan a boost and motor started and unit cools. Do I need a new motor or any have similiar problem.
  • 439 Answers
You do not need a new motor, more than likely the contacts are going bad. You can clean these or replace them if you are mechanically inclined.
Posted on Jun 25, 2009
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
I have a coleman Elect-A-Heat Mach EL R.V. Series. The water is not draining, the water built up and drained out the bottom. I am looking for diagrams to take this apart and repair it, does it have a...
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Aug 29, 2010 | Heating & Cooling
Today the blower motor started running slowly,approx.half normal speed, both high and low setting,on our Coleman Mach 3 ac unit.I believe it is orig.in our '87 Hoilday Rambler.Any ideas would be much...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO rvcomfort.com
Jul 26, 2010 | Coleman Mach III Air Conditioner
I need a motot for a coleman mach el
GO TO rvcomfort.com
Sep 28, 2009 | Dometic Rooftop RV Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
