Amana Air Command 80 blower won't come on
Amana Air Command 80 with EWC zoning condenser working but blower won't come on, zoning system calling for both zones
  • 614 Answers
Sounds like fan relay or fan motor possibly capacitor. Call a service tech for free estimate on repair. that wasy you know upfront your cost.Rus
Posted on Jun 25, 2009
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Mar 02, 2010 | Heating & Cooling
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Amana Air Command 90 - Model GSC075A30A
water should never reach the nipple for the pressure switch tubing on the IDM. Check the entire condensate drain system for obstructions. Verify water makes it from the furnace location to the outside drain. Flush p-traps and any anti-siphon devices thoroughly.
Jan 17, 2009 | Heating & Cooling
Amana Gas furnace, Air Command 80 SV. Does not ignite. The blower turns on, then gas valve opens. I can hear a mechanical switch close, which is probably the igniter control. But no spark, no flame. ...
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Dec 02, 2008 | Amana Heating & Cooling
Woke to a squealing noise Amana Air Command 80
blower bearing can make that noise. reach in to the motor shaft and see if it can spin freely if not than mtr has seized. also try moving it side to side (not in and out of mtr ) if there is play bearings are going out. also check blower wheel blades make sure they are tight.
Nov 21, 2008 | Amana PTH123B25AJ Heat Pump Air...
I have a Amana air command 80 sse central air unit. The unit is comprised of a big fan unit outside, and a unit in my garage. The big fan stays on even though I turn the thermostat off. Do you know what...
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Oct 16, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
371 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
