Akai LCT3201AD 32 in. LCD Television Logo
michelle criswell Posted on May 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv comes on but i cant get any reception it says that I need a DTV intial, what is that
Level 3:
Top Expert:
  • Akai Master 76,851 Answers
  • Posted on May 28, 2014
Akai Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994002
Points
237762
Your TV need initilization. Contact the authorized service centre. Gopakumar Gopalan Google
Cant find the remote for dtv 322 intial brand need to program this tv
A universal remote control has cross functionalities capable of powering several devices. Acquire one from the retail market.
My dtv pal dvr is a few months old and is unusable. It freezes up sometimes for hours i cant even turn it off. The content comes off an antenna that gets a strong signal but it skips like it is getting bad...
Hello! Dan Busa with DISH Network customer service. This may be a signal reception problem you can try checking cabling and connections coming from your antennae.
Transponder message keeps coming up but no reception
check the coax ends you may not be getting a signal to the box especially the ones outside. any that are corroded needs to be replaced.
1helpful
2answers
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
3helpful
2answers
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
1helpful
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Dtv switch
yes if runing sat or cable, if your using antena you will need dtv antena and dtv box for reception.
regards,
daniel.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
