Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Riding mower having problems starting then runs roughly
I have a Murray riding mower,while riding it just shut down.Put in new spark plugs,changed fuel filter and checked battery.Starts on occasion but runs rough and acts as if it is going to die.Could this be bad battery cables?
  • jkirby1212 Jun 25, 2009
    Was told it didn't have a carburator on this Murray riding mower.Air filter is clean.Thanks for the advice
    Don't know model no. but it is a murray 12.5 HP 38in.cut.Tried to start this am,sounds like it's trying to start but smells like gas.Air filter is clean and just changed spark plug and fuel filter,no luck.It is about 17 years old,is it expensive if it needs a new carburetor?Thanks for your help.
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
    Habit-Forming:
  • 17 Answers
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Posted on Jun 25, 2009
  • William Fouts Jun 25, 2009
    Give me the model number so I can look it up........I am sure it has a carb.!
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Murray 42506x92A (1998) 42" Lawn Tractor, starts easy, but surges and dies. Over and over... It acts like it is running out of fuel. I changed the fuel filter and spark plug, but no improvement.
Check the fuel bowl to see if anything thing is in it. If it has a auto shut switch on the bottom of the bowl, it may be the cause as well. Next check that the valves (ohv) are adjusted right.
Oct 08, 2014 | Garden
My murray lawn tractor stops running after 10-20 minutes. I replaced the fuel filter and cap, spark plug, oil, gas. I do not have a spark after it cuts off. Any ideas??
First I would bypass all the safety interlocks and see if it still shuts down, if so I would test the ignition switch and if that does not find the problem, the kill wire may be shorting to the block under one of the wire clamps. If all that fails, try replacing the coil.
junkl
Feb 10, 2013 | Murray Garden
My riding lawn mower abruptly (following day after usage) started spuddering and running rough.
I would change the fuel filter and also check the carb. may be some dirt or grime holding it back. Also after changing the fuel filter run some chemtool or preferred fuel treatment through it.
Sep 19, 2012 | Murray Garden
We have a murray riding lawn mower 287707 it turns over and it wont start. Spark plug new and it sparks and just changed oil, cleaned carbuator, new fuel line and new air filter we tried everything. Can...
on the bottom of the carb there is a solenoid if that solenoid doesn't have power it shuts it off a bad safety switch will cause it to not have power if so start with the clutch/brake switch
Jun 03, 2012 | Briggs & Stratton Garden
My Sears Riding Mower Runs Rough & Backfires
don't know the model but check the valve adjustment
Apr 07, 2012 | Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Aug 25, 2011 | Garden
My john deere lx 280 is running rough and sputtering
The problem is either withe the coils or with the ignitors,the ignitors don't usually cause the problems that you're discribing but the coils can come and go as the temperature changes so i would start there.
Jul 18, 2010 | John Deere Gator and riding mower deluxe...
I have a Murray riding lawn mower Model 425600x8A. Recently, my son and I were using it to mow on a hill when it starting putting out a thick white cloud of smoke. We shut the engine off and let it cool...
The oil entered the cyliders when the mower was tipped at a severe angle. It will clear out after you run it for awhile. Check the oil level to make sure it is full. It could even be overfull and this is what caused the smoke. If it starts to run badly, check the spark plug or plugs. They could get "fouled" from the oil. Change the if the are black or covered with oil. It shouldn't have done any damage to the engine.
Jun 23, 2009 | Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
826 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
