Question about Boating
Trouble with Mercruiser Alpha 1
After shifting our boat into gear, we get a clunking sound. We have play at the prop shaft. Heavy vibration when driving the boat slow.
What is the order of assembly(fiber washers and steel washers) for mercruiser i/o front engine mount
Ihave installed incorrectly and have excessive vibration?
Posted on Jun 13, 2010
    Sergeant:
  • 353 Answers
Time to get rebuilt
i would not run it again til a pro lays his hand on it and tells you otherwise
hopefully it is still rebuildable
good luck
Posted on Jun 25, 2009
MK55T vibrates badly from 75-100 power. Shakes the whole boat. No line under prop. Prop brand new.
Why did you put on a new prop? Did you hit something and break the old prop? You might have bent the prop shaft which would cause the vibration. Wouldn't feel it at lower speeds.
Apr 01, 2018 | Boating
I have a Donzi boat with a mercruiser alpha 1 drive and a 5.7 liter engine There is a wire coming from the distributor to a closed contact on the forward and reverse cables at the motor what is this
This wire actually KILLS the ignition for a short period while shifting into reverse. The thought was to lengthen the life of the clutch dog and reverse gear, especially during "abusive" shifts into reverse from a high speed forward position. Most folks never realize it's there, and usually requires no maintenance or attention!
Sep 17, 2017 | Boating
I have a 1986 mercury outboard motor, thunderbolt ignition, 50HP, 4 cylinder. Forward gear works great. Reverse gear works very slowly , moves boat very slow and weak. Appreciate any help.TY
there is no gear box as such in an outboard leg it is just a clutch dog that is slid from front to rear to engage the cogs attached to the prop shaft
the related gear forward or reverse is attached to the shaft with a drive pin or splines
you will have to pull the unit apart to find what section has failed as it appears that the cog on the shaft is slipping ( sheared pin or failed splines in cog)
Mar 28, 2017 | Mercury Boating
REPLACE THE PUMP AND BOAT WANT GO IN GEAR
the gear shift shaft/rod pushes down on a metal wedge inside the gear box this forces a dog clutch to engage a gear and transfer the engine drive to the prop shaft along the prop. A return spring keeps the dog clutch against the wedge so that when the shift shaft/rod is lifted the dog clutch disengages (neutral) if you keep lifting another gear is engaged, astern. Missing one of the gears, adjustment. No gears, shaft/rod alignment. Is yours direct mechanically hard linked or does a cable transfer the movement to the shaft? Check the top shift connections first, before taking the leg apart again.
Hope the above, windy reply is useful.
Feb 28, 2016 | Mercury Water Pump Impeller Kit, Mariner...
Took prop off of alpha one 2007 v6 mercruiser and the shaft still turns in gear and makes a clicking sound inside lower unit?
If it is in gear and you are turning it anti clockwise by hand it will make a clicking sound
Sep 01, 2014 | Boating
2003 F350 6L Diesel, 6 speed manual transmission. Vibration/noise right front when under medium to heavy acceleration, vibration/noise becomes very prominent starting at 1900 rpm in all gears (still can...
Rob, assuming this is a 4X4? Sounds like a bearing. They can vibrate, snap, clunk, all kinds of terrible noises or vibrations.
Axle u joints will also do this. Is it all wheel drive?
Nov 02, 2013 | Ford F-350 Cars & Trucks
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
1989 Suzuki Sidekick rear differentials
GET IT TO A MECHANIC!! Something is loose or about to collapse! Remember that vibration and noise can travel away from the source so get the mechanic to start in that corner.
You need to get the following checked!
-Prop shaft mountings at transfer box.
-Prop shaft mountings at differential.
-Prop shaft bearings.
-Differential condition and oil level.
-Drive shafts at differential end.
-Drive shafts at the wheel end.
-All flexing joints in the system including UV joints and CV joints.
Feb 04, 2018 | Suzuki Sidekick Cars & Trucks
When i slow down to 20 mph as it shifts down it clunks. and as i am parked and i try to put it in gear it makes the same clunk sound.
it sounds like you may have a bad universal joint in one of the drive shafts,more likely in the main shaft that runs from the transmission to the rear differential.
Mar 24, 2011 | Jeep Grand Cherokee Cars & Trucks
Boating Logo
582 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
