2005 GMC Sierra Logo
Posted on Jun 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
100,000 miles check list - 2005 GMC Sierra
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Jun 25, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972475
Points
24702
Ok, this actual model will hold up quite well under moderate driving conditions but, you will need ot do a few things here. check the list below for further information.
CHECK LIST(100,000mi)
1 Spark Plugs-replace asap
2. Automatic Trans Fluid Filter-replace asap
3. Automatic Trans Fluid-change asap
4. Ignition Cable(s)- Inspect for damage and, change if damage is visible.
5. Inspect the engine oil and filter.
6. Finally, get a basic lube job.
PO171 system too lean (bank 1)
The check engine light is on ?? Yes? Check the pre catalitic converter Oxygen sensor or upstream sensor. If the car has in excess of 100,000 miles it's probably bad. If it has less than 100,000 take it back to the dealer because these things have a warranty that is federally mandated for 100,000.
3helpful
2answers
My chevy has about 98000 miles. When is tune up recommended.what is involved in the tune up?
what engine? The fuel filter is in the fuel tank, Spark plugs should be replaced, throttle body cleaned, and the truck generally checked over, battery , belts, brakes, tires ect. Spark plugs, trans fluid, filter, transfer case fluid change, are all due at 100k. You should have the 100K service done. Of course they base that on if you have been following the service schedule. Your owners manual will list all things that are due.
3answers
When should the spark plugs on a 2005 cobalt be replaced?
The recommended replacement of spark plugs on your car is every 100,000 miles.
1helpful
2005 cts @ 100,000 what service needs to be done?
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - EXHAUST SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - AIR CLEANER/ELEMENT - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL FILTER - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - SPARK PLUGS - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - TIRES - ROTATE - [Tires should be rotated every 5000 to 8000 miles, and/or at maintenance I or II service intervals.Check tire pressure, thread depth and wear.]
2helpful
My jeep wrangler just passed 100,000 miles, what service does it need?
Here is the basic maintenance list for your Jeep:
~ Inspect lights and check tire pressure at least monthly or before & after each trail ride
~ Oil & filter change, chassis lubrication, differential and transfer-case fluids every 3,000 to 5,000 miles or 3 to 4 months - if you have recently crossed through water deep enough to submerge the centre of your hubs, replace the differential fluids as a precaution
~ Underhood belt and hose inspection every 3,000 to 5,000 miles or 3 to 4 months (every oil change)
~ Tire rotation and wheel balancing every 6,000 miles or every other oil change - driving offroad can knock wheel weights off a wheel, so you may need to have this done more frequently
~ Brake inspection every 6,000 miles or every other oil change - if you have rum brakes in the rear, ensure they are cleaned after each trail ride where you encountered deep mud/snow
~ Replace air filter every 12,000 to 24,000 miles or as indicated by inspection - dusty trails can shorten these intervals dramatically
~ Replace fuel filter every 24,000 to 100,000 miles
~ Automatic transmission service every 24,000 to 100,000 miles
~ Wheel alignment check every 12,000 to 24,000 miles or as indicated by tire wear - offroad driving can knock wheels out of alignment, so budget for an alignment every 3 months, then watch tread wear to see if it's needed
~ Cooling system flush and refill every 40,000 to 100,000 miles
~ Belt and hose replacement every 60,000 to 100,000 miles or 5 to 8 years
~ Engine timing belt replacement every 60,000 to 100,000 miles (when equipped) or 5 to 8 years
~ Air conditioning performance check annually, usually in the spring - be sure to run your A/C during the winter for brief period to ensure all hoses and valves stay lubricated and operable
1helpful
2answers
How often do you change a timing belt in a 1995 toyota corolla?
Provided the belt that is to be used is a high quality belt such as a Gates brand the belt can safely last for 80,000 to 90,000 miles before needing to be changed. As for the original belt usually for hondas it's 100,000 miles Toyotas about the same 100,000 to 110,000 miles, check with your local dealership's service department for you cars original belt Suzukis and kias are about 90,000 miles.
Want to know what maintenance is needed for 2001 Subaru Outback for 120,000 miles.
timing belt needs to be replaced at 100,000 miles, auto transmission fluid and filter replaced, that is really the only things, of course u check all fluid levels, the big maint is the 100,000 mile service
1helpful
2answers
Just reached 100,000 miles, chech engine light
Go get an OBDII check and it should tell you, i dont think there is any corrielation between the milage and the check engine light
2helpful
2answers
116,000 miles and going. running great. just had all fluids replaced and checked and tires rotated. do I need to take it in for some major overhaul appt like Acura keeps suggesting since its over the...
u need the timing belt replaced like yesterday, u are playing russian roulette with it breaking. also the plugs should have been repalced at 100,000 miles.
1helpful
Just wanted to see if anyone could give me a complete list of supplies needed to tune up a 2004 chevy silverado 2500HD 8c 6L
that depends on the miles on the truck. spark plugs every 100,000 miles, other ignition parts inspect and replace as ness, fuel and air filter every 30,000 miles. all belts and hoses should be inspected as part of any service.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
