Question about Whirlpool ET1NHMXKT Top Freezer Refrigerator
Whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
I have water accumulating under the crispers, I suspect that it is a clogged drain but don't know where to begin
    President:
  • 1,136 Answers
Hhi, Yes the drain is plugged. remove the floor panel in the freezer and then the rear panel. Locate the drain hole (right side of drain pan) and melt all the ice. there is an after market drain heater kit that you will need to buy and add to the defrost heater.
It is a design problem. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 25, 2009
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Water leakage out of fridge
it may drain hose is loose
Jun 04, 2010 | LG Refrigerators
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Fridge problem
There is a drain, usually at the bottom of the refrigerator compartment. Pull out the bottom two drawers and see if there is a drain. It is usually in the very back of the inside compartment. Make sure it is not clogged. Usually, this is the problem.
Oct 18, 2008 | Frigidaire Refrigerators
Water accumulates under the crisper
hi thanks for the question you have a clogged drain hose from the freezer to the drain tray underneath the fridge clean that tube it should be fine thanks the appliance doc
Sep 27, 2008 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Whirlpool ET1NHMXKT Top Freezer Refrigerator Logo
176 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
