Question about Kenwood KDC-MP335 CD Player
I cant turn up my subs - Kenwood KDC-MP335 CD Player
  • 578 Answers
Why
Posted on Jun 26, 2009
My sub wont come on. but all the outher speakers work fine . cant figure it out?
I assume this is connected to a AV Receiver? There is generally a low level sub out, with an RCA jack. That should go to your sub input. The old subs had the speaker outputs on the back of the receiver connected to the sub input, and all the other speakers were connected to the sub, but that system hasn't been used in decades.
Jan 24, 2015 | Audio Players & Recorders
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
I have 2 RCA's running subs and interior speakers. for some reason when i turn it up the subs it sound like its going to blow. could this be a problem if the RCA was mixed up for example the sub rca going...
Possible but highly unlikely. You cant check them to be sure if not, check to see if the amp for your subs has a phase switch on it. Also check to see if is has a bypass EQ and change it to a lower setting (low pass filter). Good Luck.
Feb 21, 2011 | RCA Car Audio & Video
I just installed a kenwood dnx7140. Everything is
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
Mar 08, 2010 | Kenwood DNX7140 Car GPS Receiver
Amp wire pushin to much base out of car speakers and not to subs
Umm.. subs are usually meant for bass. do you mean amp power wire? if you just want to be able to hear the mid's and highs better just turn the bass down either on the equalizer on your amp or on your cd player.
Jun 27, 2009 | 1996 Ford Thunderbird LX
CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Sherwood RD-6108 Receiver
I HOOKED UP MY SUB AND NOW ITS MAKING A loud squelching noise i cant figure it out please help
try taking out your rca leads and turning the amp on. if it stil makes the noise try using a diffrent sub 2 see if the sub is gone. mite be broken leads.
Dec 27, 2008 | Car Audio & Video
Aux and sub settings
you have to turn the headunit off using the headunit (there is a button that says off or power just cant remember which one) once its off and is displaying only the time you hold the function button and all the other options will come up.
Jun 29, 2008 | Pioneer DEH-P6400 CD Player
Problem!
you have a foulty amp i wtake it bk and change it
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KDC-MP335 CD Player Logo
56 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
